Old 06-07-2011, 03:50 PM
ojibberish is on a distinguished road
Exceeding servo drive power rating
Hello,
I have a 100W brushless servo drive (technosoft motion controller), and I would like to drive a 200W brushless servo (servodisc). Both the motor and the drive run on 24VDC, but the drive puts out 5A, and I need 10A or more. If I don't need full performance, will just hooking the motor up work without trouble? Or, will the low impedance load burn up my drive? I've also considered an external push-pull emitter follower transistor network on the output of my drive.
Thanks!
Old 06-07-2011, 07:38 PM
mike_Kilroy is on a distinguished road
ur scenario will work fine, just limit the motor capability. assuming it is a decently designed drive it should be fine. absolutely NO issue with inductance etc u mention.
[IMG] code is Off
Power supply voltage exceeding 160V ikke1983 Granite Devices 11 05-12-2011 11:14 AM
DISabling servo drive power on a DX/SX system wjr09 Bridgeport and Hardinge Mills 25 10-10-2010 10:16 PM
servo alarm 51(current command exceeding) on mits m50l Chuck Reamer Mazak, Mitsubishi, Mazatrol 23 03-05-2008 07:06 AM
servo alarm 51(current command exceeding) on Lynx. Chuck Reamer Daewoo/Doosan 3 01-31-2008 05:11 PM
power supply sizing vs. servo rating Erick Davidson General Electronics Discussion 1 06-06-2006 03:08 PM
