Old 06-07-2011, 10:59 AM
Jackal66 is on a distinguished road
Need info on servo motor
I have electrocraft servos on my Hurco.
What are the identification of these wires?
The small wrapped wires go to the encoder.
Name:	servo wires.JPG
Also, I was wondering about these brushes????
There are (4) large caps with a brush under each. They are 90*deg spaced around the motor. I want to take these out and clean them and blow out all of the carbon.
The other one ( green arrow) must be the tach brush. I was wanting to remove the tach brush & spring,since it won't be used. I don't want it wearing out and ruining the armature.
Will the motor run ok with out the tach brush?
Here is the name plate on the motor if needed.
Name:	servo nameplate.JPG
Thanks,
JAckal
Everything is bio-degradable, if you run over it enough times with the lawnmower.
Old 06-07-2011, 11:16 AM
Al_The_Man's Avatar
I would think the four are Tach pair and motor pair?
If so it will be easy to check, either with a resistance check to a brush holder or check resistance to isolate each pair and then take the Tach brushes out and see which pair is now open.
The tach is not needed with Torque mode amps, It is OK to remove the brushes.
Old 06-07-2011, 01:52 PM
Thanks Al,
I checked and the blue & white wires are for the tach.
The od of the insulation is the same as black & red ones, but the wire gauge is smaller.
After removing the brush they are open now.
Just leaving this info in case anyone else needs to know.
JAckal
Old 06-07-2011, 02:28 PM
Al_The_Man's Avatar
The problem is that Electro-Craft made many of these type of motors for OEM's with their in-house part No, so the specs are not always that easy to come by.
[IMG] code is Off
Help Need Info On Vexta Servo Motor m.southern Servo Motors and Drives 9 10-13-2011 10:58 AM
Looking for info on Toasiba AC servo motor jim_geib Servo Motors and Drives 0 01-24-2010 08:26 PM
Need Help!- Info on Panasonic Servo Motor MWJ2009 Servo Motors and Drives 3 09-30-2009 02:37 PM
Info Needed Omron 500 W Ac Servo Motor robo_plasma Servo Motors and Drives 0 01-06-2007 06:30 PM
Servo motor info please! mmmjboner Servo Motors and Drives 1 12-14-2006 09:52 AM
