Indrek,Originally Posted by ints99
Hello! I'm not sure what is appropriate for your mill. Check the classifieds here at the site and see my add for the E-712 ElectroCraft 1500 oz-in servos. All of the specs are there: look and see. These are 300 oz-in continuous and peak at 1500 oz-in at 45 amps. If you derated the supply to only supply 20 amps (to math the Gecko's maximum output) you would still be able to pull 600-700 oz-in peak.
Given that you need to speed reduce a servos speed by a factor of three or four, you are automatically boosting the torque at the screw by the same factor. In other words a 150 oz-in continuous rated servo with a 3:1 reduction is going to give you 450 oz-in of torque to the lead screw. and the screw gives even more torque multiplication itself.
Lance
LinkBack URL
About LinkBacks
