Old 04-30-2011, 11:09 AM
matttargett4 is on a distinguished road
What current setting for these motors???
Hi all,
I have a machine that uses electrocraft e-586 motors and im really not sure what i should set my max current value at, im running a supply voltage tot he drives of 63v, here are the motor specs i found after searching
cont. stall torque 29 oz-in
pk torque 240 oz-in
Max terminal voltage 60
max rpm 6000
inertia .0052 0z-in-sec^
tach 14v/1000rpm
armature ind. 3mH
Any help would be greatly appreciated.
Matt
Old 04-30-2011, 12:06 PM
Al_The_Man's Avatar
The Kt (torque constant, 0z-amp) for that motor is ~10.
Check out the Emerson explanation for calculating the current settings.
http://www.emersonct.com/download_us...es/ctan146.pdf
[IMG] code is Off
Need Help!- Current setting for TB6560 3-axis board (eBay) leaveme DIY-CNC Router Table Machines 4 06-24-2011 03:55 AM
Need Help!- current, decay setting question... jaru-eri Stepper Motors and Drives 3 01-08-2010 03:44 AM
Transfer current setting to new PC CPierce18 Mach Software (ArtSoft software) 3 01-19-2008 08:26 PM
How much current does my PS need to supply for my motors? cnczoner General Electronics Discussion 1 08-20-2007 10:17 PM
Drive Current Setting Question electron Stepper Motors and Drives 1 03-21-2006 07:52 PM
