Old 08-24-2005, 03:42 PM
bboggess is on a distinguished road
Cool peak vs stall torque
I have noticed some servo motors have a peak and stall torque rating. Can someone explain to me the difference between peak and stall torque? doesn't a motor stall when it reaches peak torque?
Old 08-24-2005, 05:45 PM
Gold Member
Mariss Freimanis is on a distinguished road
It's a bad choice of terms but it is a standard.
Maximum Continuous Stall Torque: This is actually the maximum continuous torque rating for a motor. The emphasis is on 'continuous' as in 'do not exceed except for short periods of time'. You do, you burn your motor down.
Peak Stall Torque: This is the torque the motor will deliver if its shaft is prevented from turning. This is a more impressive number so manufacturers and vendors tout it.
Typically Peak torque is 5 to 10 times greater than Continuous torque. Current is directly proportional to torque so peak current is 5 to 10 times the continuous rating.
Motor heating goes up with the square of the current, being primarily 'I-squared-R'. This means the motor will develop between 25 times to 100 times more heat than it can safely dissipate while delivering peak stall torque. Not a good thing; keep your load at or below the max continuous torque limit.
Mariss
Mariss
Old 08-24-2005, 07:36 PM
Evodyne's Avatar
Evodyne is on a distinguished road
Hi! Take a peek at this thread. where the same discussion is going on with respect to sizing power supplies. We've played with the specs from a user's servo motors and it illustrates exactly what Mariss said.
Lance
Old 08-25-2005, 12:56 PM
Makes sense. Thanks for the explanation.
[IMG] code is Off
