Old 04-22-2011, 12:12 AM
RP Designs is on a distinguished road
Servo amplifiers and BEMF
So I am doing my research as I get going on my project and I am trying to figure out if I need to protect the servo amps from back emf. The drives have shunt regulators which shunt the BEMF to the power supply, but since amplifiers don't have a power supply do they have a dissipative element or should I somehow protect the amp from the back emf? How is this typically done in practice?
Old 04-22-2011, 08:50 AM
Al_The_Man's Avatar
"but since amplifiers don't have a power supply"
Generally all modern drive have a P.S. either external or internal, unless it is a SCR drive, which is not all that common, at least for new installations.
As a general design rule, most have switching devices that have reverse EMF protection built in, as well as reverse diodes fitted across the devices.
If you google simple H bridge designs you can get the idea of what is used.
Old 04-22-2011, 09:49 AM
Thanks Al, as always!
[IMG] code is Off
What control signals are sent to the servo amplifiers? Pplug Techno CNC 7 05-01-2010 01:48 PM
FANUC 0M-C servo Motors & amplifiers gbowne1 Fanuc 5 07-03-2009 12:08 AM
FANUC 0M Servo Amplifiers gbowne1 Fanuc 6 06-27-2009 10:55 AM
Servo Amplifiers at 240V CalG General Electronics Discussion 0 03-26-2009 09:35 PM
Trying to identify some servo amplifiers wpy Bridgeport and Hardinge Mills 19 11-08-2007 05:48 PM
