Results 1 to 6 of 6
Thread: Gettys/Gould Servo Motor Datasheets
    Mar 2011
    U.S.
    I've got a couple old DC servo motors that I'm going to use on a retrofit project and I'm looking for the datasheets so I know what drives to get for them. I've had no luck with Google.
    The first one is a Gettys
    Datasheet: 201-113-3003
    And the other is a Gould
    Cat: 16-0375-88
    Datasheet: 201-133-2143
    Any help is appreciated.
    Dec 2003
    You may have better luck just reverse engineering them, the voltage can be obtained by either using an external DC source to check the rpm at a given rpm, or back feed them and measure the DC voltage produced, then extrapolate for ~2000rpm, which this was about tops for these motors, most were built for 120vdc.
    If you measure the frame size, I can pretty much tell you the rough torque value.
    Sep 2010
    Closest data I have is on 16-0375-70 (same as 20-2) & 16-0376-36 (same as 30-2)... they used these 16-xxxx-xx numbers to identify the actual motor and its options, they used the 201-xxx numbers to identify the speed torque curves for the motors.
    found data sheets on Type 16-0372-05, Catalog no. 20-2130-8, Data 201-113-2024 - it too is a size 20 model.
    Looks like your best bet is to measure & post complete dimensions of each and then they can be matched up to the std catalog sheets that do have all this info.
    Sep 2012
    I have a gettys motor that has a value of 333 lb/in at full torque,, 222 lb/in at running torque, its on a rotary table I need to get a controller for, have found that its max speed is 1400 rpm, it has a tach on the back side, and I believe there is an encoder, but am still trying to decifer its value. I need a controller for it. Am building a 4 axis horizontal mill.
    The rotary table is the most important axis, as the Y and Z are only being stepped, in increments of around .040 th's. Using the table,, as full 360 deg' continuous drive.
    Sep 2010
    Like Ed did in first post here a year ago, list ALL the stuff on the motor nametag and motor dimensions. if nametag is on it someone may have a data sheet on it....
    Mike (at) KilroyWasHere (dot) com -- servo/spindle/vfd motors/drives/controls sales/service/repair/retrofit
    Dec 2003
    The controller type is also required and the nature of the commands signal, i.e. ±10vdc, step/dir etc?
    1. Gould\Gettys Servo Motor
      By Mits in forum Servo Motors and Drives
      Last Post: 01-27-2011, 12:44 PM
    2. Need Help!- URGENT - Gould Gettys N360 Three Phase Half Wave Controller
      By ElectroMachine in forum Servo Motors and Drives
      Last Post: 02-05-2010, 12:26 PM
    3. Need Help!- Gettys Gould DC servo motor catalog
      By SHIVAMN in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 07-24-2009, 04:11 AM
    4. Need Help!- Gould Gettys 410 Serial Coms
      By BMTS in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 03-28-2009, 06:22 AM
    5. gould gettys servo motors
      By kollander in forum Servo Motors and Drives
      Last Post: 12-25-2006, 01:14 PM
