I have Reliance catalogues going back to 1990 and they do not show a E440 I suspect they supplied these under a customer order as they often did, with a unique number on it, the beauty of DC motors is they are fairly easy to reverse engineer and flexible to incorporate into different drives, there have been several previous posts to this effect I believe.
Renco, I have found good as to suppling info on their part No's. In a pinch, you can unsolder the two LED leads and take the top board off to reveal the disk, it will have the resolution etched in and also youcan see the marker pulse if it has one.
The output IC will tell you what type of output, differential or single ended.
LinkBack URL
About LinkBacks
