Old 03-20-2011, 07:14 PM
williamsmotower is on a distinguished road
Rotary encoder wiring help please!
I have a Heidenhain ROD 426B rotary encoder
Pages 50 and 51 of this link show wiring diagram
http://www.heidenhain.com/fileadmin/...349_529-29.pdf
This encoder in incremental and is to be used for a camshaft test stand.
The wiring the company that made the circuit board wants me to wire it as follows (I included the color of wires I wired it as from my deciphering of the Heidenhain wiring)
DB9 male plug:
pin:
1 VCC 5 volts (i used blue wire)
2 quadrature A (i used brown wire)
3 quadrature B (i used green wire, and tried gray wire)
4 reference (i used red wire)
5 ground (i used the shielding sheath of the encoder wiring bundle)
When I turn encoder by hand it's not registering.
Thank you for looking at this, and help would be appreciated! Jesse
Old 03-20-2011, 08:46 PM
Another bit of info. I took casing off encoder to see if I could see the light that shines on the encoding wheel.
If this is powered on should I be able to see this light at all.. or should it be to faint to see?
Old 03-20-2011, 10:29 PM
Al_The_Man's Avatar
It appears White/grn = 0v, Brown/Grn =5v, Brown=A Gray=B, Red=Z.
You won't see any light, they are infra-red, you should see 5vTTL unless it is the low level sine wave version.
Old 03-21-2011, 12:47 AM
I got a bite! Thanks Al!
But.... I'm still confused.
Here is the wires I have coming off encoder...
blue
brown small gauge
brown bigger gauge
gray
red
green
pink
yellow
violet
white small gauge
white bigger gauge
black
since I have no brown/green (this means a brown wire with green markings to me... does that mean I use the brown and green wire on the same terminal?
Or at the risk of getting flamed for not figuring this out myself... with the info provided above could you tell me how to wire this correctly and fill in the blanks for this?
DB9 male plug:
pin:
1 VCC 5 volts ________
2 quadrature A _________
3 quadrature B ________
4 reference _______
5 ground _________
Old 03-21-2011, 12:40 PM
Al_The_Man's Avatar
Well I have most of the Heidenhain pinout colour and I cannot find that particular combination?
The ROD426 TTL encoder I have shows.
Blue =sensor power +5v
White =sensor 0v
White/Grn =Power common (0v)
Brown/Green =+5v supply
brown = A
green = /A
gray =B
pink =/B
red =Z
black =/Z
Yellow =N/C
Do not use the shield as common.
[IMG] code is Off
EMC2 and a rotary encoder supahonkey LinuxCNC (formerly EMC2) 19 12-01-2008 11:35 PM
rotary encoder help anslee Linear and Rotary Motion 0 11-17-2008 07:24 PM
encoder wiring ???? jshumer1 Bridgeport and Hardinge Mills 2 01-16-2008 02:30 AM
Pic encoder wiring A B i and T gurvy PIC Programing / Design 3 08-16-2007 08:03 AM
Encoder wiring balsaman Gecko Drives 15 12-30-2003 11:01 AM
