Old 02-25-2011, 04:33 PM
Maglin is on a distinguished road
AMT BD30A Servo Drives going to work here?
I'm trying to get my servo config down here. I'm doing a RF45 conversion and want to use the Keilling 850oz DC servo motors. I found some BD30A8B drives pretty cheap. I'm looking to use the AMT encoders for Keiling as well. I know these drives will worth on both brushed and brushless motors. What I don't know is will I be able to run them in EMC in closed loop? They are PWM/dir drives.
Also are they even decent servo drives? I seem them from $80 up to $500 for the same drive. From the looks on the spec sheet it's PWM only. I'm new to servo's and just looking for the right setup.
Old 02-25-2011, 09:40 PM
Iron-Man's Avatar
Iron-Man is on a distinguished road
+- 10V servo amps
You will want to start here; NC-Mill-How-To
and here, LinuxCNC.org - HostMot2 Driver .
Hope this helps,
Iron-Man
Old 02-25-2011, 10:01 PM
I forgot to put what electronics I was thinking might be what I needed. I'm definitely going either 5i20 or 5i23. For the daughter cards for the drives I'm thinking the 7i37TA might be what I want for a PWM/Dir scheme.
[IMG] code is Off
Drives work opposite eachother (one goes wrong way) when referencing X Matt Clara Mach Software (ArtSoft software) 20 10-17-2010 05:49 AM
VSD Servo Drives jnnewton DIY-CNC Router Table Machines 1 10-01-2010 09:31 AM
Change motors and drives or work with these? flhr97 Servo Motors and Drives 0 08-04-2008 06:40 PM
will mach3 work with gecko drives derkiow Gecko Drives 11 11-15-2006 01:29 PM
Variable Frequency Drives...how do they work? mastercnc General Electronics Discussion 4 05-27-2004 08:59 PM
