Old 02-14-2011, 02:15 AM
sjh sjh is offline
sjh is on a distinguished road
need to purchase an encoder
I have a Mazak Vertical machining center. While transport Zaxis servo motor's encoder is broken.
Technical spe. of encoder and motor are attached.
Can u help me to purchase it?
thanks
sjh
ID:	126454   Click image for larger version
Old 02-14-2011, 07:11 AM
johyn's Avatar
johyn is on a distinguished road
google?
PDF
http://www.atechauthority.com/produc...type=18&id=162
Old 02-14-2011, 08:36 AM
gasto is on a distinguished road
mitsubishi encoder
You should try contacting Mitsubishi first. They may refer you to Mazak since the motor & encoder is made OEM for Mazak. Or try to find an encoder repair facility in your area.
Good Luck
Old 02-15-2011, 08:20 AM
payneibex is on a distinguished road
I believe this encoder is phased to the motor. Most inverter type servo drives require the encoder and motor to be phased to each other to work properly.
Old 02-15-2011, 09:55 AM
ozzb is on a distinguished road
repairs
Check these guys out
Endeavor Technologies, Inc
Old 02-15-2011, 11:41 AM
prabhus_19 is on a distinguished road
encoder for mitsubishi servo
dear sjh,
pl follow the following steps:
identify the following :
1.the number of pulses on the disc( some marking will be definetly there)
2.the bore size
3.The operating voltage and type of interface of the encoder.
In case you have the number signal lines connected between the drive and encoder its much easier to identify.
Once you have identified then approach encoder supplier across for a the best matching encoder.
All the very best
Old 02-15-2011, 12:36 PM
Al_The_Man's Avatar
Its an AC servo motor and the commutation pulses are automatically aligned when you replace the encoder,
See this recent posting for the details on the encoder coupler.
http://www.cnczone.com/forums/mazak_...oud_noice.html
They are hard to sub as they are proprietary to Mitsubishi.
[IMG] code is Off
DIY or Purchase a Kit??? C.Des DIY-CNC Router Table Machines 3 02-05-2010 11:58 AM
Need help with first cnc purchase Legdoc Want To Buy...Need help! 0 01-07-2010 07:16 PM
Considering a purchase Cooperd0g Tormach PCNC 4 08-06-2009 03:53 PM
after a purchase then what woodman08 Commercial CNC Wood Routers 3 10-18-2007 11:37 PM
How to tell if my motor is Pulse encoder or quadrature encoder? Darc Servo Motors and Drives 0 07-22-2005 03:51 AM
