| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
| Dear All, I'm new to CNC machine building. My first assignment is to work on a high precision machine using Linear motor. It has 2 axes (X & Z) both identical in mechanical and electrical/electronic aspects. Z axis works fine all the time. But the X axis faces problem like Run-away, jerky motion, vibration and improper direction sense. The driver trips stating error like over-loading & over-speeding during the above mentioned conditions. But sometimes, if the stage is moved manually during servo-off and subsequent servo-on condition makes the stage to move continuously without any issues (though this is also not a repeatable solution, as the amplifier trips often). Also due to this erotic motion of the motor, there is fault/following error flag raised in the controller. Could there be any problem with motor??? Z axis is not at all affected by any of the above mentioned problems. following are the details of the driver, controller and motor. Panasonic driver - Customized. Umac controller from Delta tau Sodick linear motor (50mm max. travel range) - 3 phase Kindly help me in addressing this problem by providing some possible causes of the error. All your suggestions are appreciated. Thanks in advance. |
| your description is consistent with bad phasing. this does not sound like a 'bad' motor but more likely a bad feedback device. You did not say what the feedback is but with delta tau and old panasonic drive I will assume halls and incremental encoder. sounds like a loose wire on a hall feedback (there are 3) - they are used on power up to phase the system then it switches over to encoder feedback. if enc problem the DT prob would complain. so i vote for bad hall thing. btw, did it used to work? if so, what happened just before it stopped working? thats a clue. did it crash? is it new and never run yet? |
| Hi Mike, Thanks for the reply and sorry for the late response. I had sorted out the phasing problem. As you mentioned, it was due to encoder connection. just swapped A+ and A- and it did the magic. Now I face the problem of high noise level. I could segregate the noise due to three reasons: 1)Electrical 2)Environmental 3)Mechanical with electrical creating the maximum of 300nm when the servo-on condition for the 2 motors. i want to eliminate this noise and make the movement of stage much smoother because I could see hunting of the motor at stationary position and a large following error. The encoder is having a resolution of 5nm, but couldn't achieve anything near to tens of nm also. I suspect whether it may be because of SMPS of the panasonic driver. Can a linear drive solve my problem? Can you suggest any linear driver company, if you know? Thanks for your valuable reply. |
| Tags |
| driver tripping, linear motor run-away, vibration |
| Panasonic Panaterm Driver Software | gavztheouch | Servo Motors and Drives | 16 | 12-07-2011 04:25 AM |
| Need Help!- Panasonic Panadac AC servo motor driver | luckym | Servo Motors and Drives | 0 | 05-15-2010 03:24 PM |
| Need Help!- panasonic driver | manmardam | Servo Motors and Drives | 2 | 02-08-2010 01:21 PM |
| Panasonic Servo and Driver | Jim_the_one | Servo Motors and Drives | 2 | 06-25-2008 02:43 PM |
