Old 02-03-2011, 11:15 AM
MTech2 is on a distinguished road
Spindle coast to stop?
We have a kiwa excel center 4 with fanuc 10m controller. During a program cycle if the spindle is 4000 rpm or higher, and it tries to move to next step a fault occurs because the spindle is still rotating. I don't know if it's coasting or not decelerating fast enough. Any ideas on how to adjust the spindle stop or other possible fix?
Old 02-03-2011, 06:19 PM
mike_Kilroy is on a distinguished road
did it used to work?
ur description sounds like an overvoltage error. is there a db resistor on top of your machine cabinet in a metal cage? or inside the cabinet? You might check that its wires are hooked to the spindle drive or look for a fuse in series with these wires that popped. If you need to run and can afford a longer decel time, program that and you might get away without the error.
Old 04-06-2011, 09:01 AM
Thanks Mike it was a fuse in the back section of the spindle drive. I had checked this fuse while machine was running and had voltage on both sides. The fuse has a diode figure on it. Not sure how it is designed in the circuit.
[IMG] code is Off
Need Help!- Spindle does not stop hydrospin01 Colchester Tornado lathes 1 02-02-2011 11:19 PM
Need help with M05. spindle does not stop jessebpm Hyundai Kia machine 0 04-27-2010 01:10 PM
Problem- spindle won't stop HBFixedGear Fadal 4 07-07-2009 04:30 PM
How can I stop the spindle ? tmead Mach Wizards, Macros, & Addons 6 03-31-2009 10:50 PM
VMC-15: Spindle Would Not Stop ! StormWerkz Fadal 8 04-25-2007 11:30 AM
