Old 01-21-2011, 01:47 AM
galody is on a distinguished road
I found the features on the IR2130PBF
The IR2130PBF is designed as a high voltage, high speed power MOSFET and IGBT driver with three independent high and low side referenced output channels. Proprietary HVIC technology enables ruggedized monolithic construction. Logic inputs are compatible with CMOS or LSTTL outputs, down to 2.5V logic.
Some absolute maximum ratings have been concluded into several points as follow. (1)Its high side floating supply voltage would be min -0.3V and max 625V. (2)Its high side floating offset voltage would be min Vb1,2,3-25V and max Vb1,2,3+0.3V. (3)Its high side floating output voltage would be Vs1,2,3-0.3V and max Vb1,2,3+0.3V. (4)Its low side and logic fixed supply voltage would be min -0.3V and max 25V. (5)Its logic ground would be min Vcc-25V and max Vcc+0.3V. (6)Its low side output voltage would be min -0.3V and max Vcc+0.3V. (7)Its logic input voltage would be min Vss-0.3V and max Vcc+0.3V. (8)Its operational amplifier output voltage would be min Vss-0.3V and max Vcc+0.3V. (9)Its operational amplifier inverting input voltage would be min Vss-0.3V and max Vcc+0.3V. (10)Its allowable offset supply voltage transient would be max 50V/ns. (11)Its power dissipation would be max 1.5W. And so on. It should be noted that stresses above those listed in absolute maximum ratings may cause permanent damage to device.
[IMG] code is Off
What features would you like to see? CNCadmin SheetCam 16 06-12-2011 09:06 AM
10 M features A1CNC Fanuc 7 11-13-2009 01:58 PM
Fanuc features Bill Johns Fanuc 4 06-27-2009 07:47 PM
new features single phase Hypermill 5 11-21-2006 11:31 AM
Many new features have been added CNCadmin CNCzone Site News and Contests 0 04-06-2005 03:46 PM
