Old 01-03-2011, 07:50 AM
bodini is on a distinguished road
What drives/power for these servos?
Have some servos (on a machine) that read as such (see pic for full data):
stall torque: 1.6nm
rated speed: 3000 rpm
kt: 0.16 nm/a
bemf: 16.5 v/krpm
rated curr: 10A
So will G320's fit the bill? What size toroidal transformer for 3 or 4 axis?
Thanks!
Old 01-03-2011, 07:58 AM
Bubba's Avatar
Bubba is on a distinguished road
From the nameplate data, it appears that you will need ~50V Dc (3*16.5) and for a 4 axis machine, I would rate the current flow at ~(4*10*.66) or 26 Amps based on previous discussions that I have read here and elsewhere. Also, I see this unit has a tachometer and you will need an encoder to work with the Gecko. If you add an encoder, try to find one that uses <50ma current supply @5V or you will have to have a separate power supply for that. The AMT encoders seem to be in favor at the present time for the Geckos and can be found at DigiKey.
Hope this helps.
Art
Old 01-03-2011, 01:56 PM
Thank you. That brings up another question for my curiosity. What is the torque of these motors in comparison to a modern servo, such as a Keling? I mean like how many oz-in?
Thanks again. :-)
Old 01-03-2011, 02:35 PM
Al_The_Man's Avatar
1.6N-m = 1.18 lb-ft (226 0z-in).
To allow for losses etc, I would go at least 60vDC for the supply.
Usually the minimum voltage rating for the supply is motor terminal voltage +10% min.
[IMG] code is Off
Servos/ encoders/ drives??? Ark1 General Electronics Discussion 3 10-14-2010 08:16 PM
servos, drives, p/s scudzuki Benchtop Machines 8 02-08-2009 06:02 PM
Gecko Drives and Fanuc servos? Radius Gecko Drives 2 06-26-2007 08:07 PM
OT: (Larger) machine Rutex drives, 42in/LB DC brushed servos, power supply for sale PoppaBear10 Bridgeport and Hardinge Mills 0 11-08-2006 07:50 AM
servos (encoders, drives) gv71 General Electronics Discussion 3 03-31-2004 12:43 AM
