The Servo is a 750 watt AC SIA Attached is the driver/controller. Is single phase
racear
ur killing us with suspense! what is model and brand of the stuff u have?
racear
Ok, I though I attached a file and it said I did. So tell me what I need to do to attach
OK I went back thru the post and I saw Quazga's dress. Do I have to wear a Tux to post? That may be why my attachments don't attach. My doo rag is keeping me off. HeHeHe
racear
What kind of document and what size?
If you look at the upload menu it shows the size for each file type.
Al
It is a pdf file and is 2.12 mb
ps My tux dont fit no more, my back side has gotten to large(fat)
racear
Al
Just tried to upload again from another pc. it said upload failed. any more suggestions
racear
I can send you an email to send it to and I will see if I can upload it OK?
Al
you should have it be email. Can u look
It looks like there is a bit of rough translation from the Chinese.
But it appears to be a semi intelligent drive in as much as the PID loop is back to the drive, but It appears to me that you may need some outboard circuitry using the step/dir input, rather than the analogue, to give you the required pulse to equate to the .001" & 005" position steps?
I am not sure if it is the site, but right now I don't seem to be able to upload either, I even zipped it but still no luck, I will have to test it.
Al
I also zipped it and tried to send it with same failure error. Thanks man for the help.
racear
