Old 12-10-2010, 10:36 AM
ing.vic is on a distinguished road
Question Initializing servo amplifier Yaskawa CACR-IR30
Good afternoon, I'm new at this forum and i'd like you could help me.
I have a servo amplifier Yaskawa CACR-IR30 and a Yaskawa servo motor USED-22-YR32, the servo amplifier was damaged so i repaired it, my question is, is there any software or any teach pendant to initialize the servo amplifier (to make the servo tuning ) to verify that the servo amplifier is working correctly, as the servo amplifier is old I haven't found much information about it, I have the motor, encoder and communication cables, but i don't have any software to communicate the servo amplifier with the servo motor to give the necessary adjustments.
Thanks in advance!
Old 12-10-2010, 11:20 AM
cncserveng is on a distinguished road
Servo's of this type are normally set up via machine parameters and enabled through the machine tool control hardware.
I think this is a bit specialised for a user, it may be best to find a local Yaskawa drives company to help you. They may have a test rig to check it for you.
[IMG] code is Off
Need Help!- yaskawa CACR HR10SB servo pack vipansam Servo Motors and Drives 15 12-06-2009 10:39 PM
Problem- servo amplifier markjb Fadal 2 06-25-2009 08:56 AM
Yaskawa CACR-SR flinty Servo Motors and Drives 9 04-27-2009 08:11 AM
YASKAWA CACR SR CACRSR JASEPH Index CNC lathe 0 01-02-2009 10:48 AM
servo amplifier frankg521 Servo Motors and Drives 22 07-20-2007 07:29 AM
