Old 11-15-2010, 02:30 PM
kben77 is on a distinguished road
Yaksawa SGDH Drive and motor BRAKE ???
I have a Yaksawa single phase 220V SGDH Drive and a matched SGMPH motor. The motor has an absolute encoder and a brake.
I am trying to JOG the motor from the Panel Operator. I have the motor and encoder plugged into the Drive and I can set Fn002 to "jog"
but ... what do I need to do to release the brake ? The manual is not that helpful. The shaft will not spin when not powered so I assume the brake is holding it. The motor has U, V, W connected to the drive. Do I need to provide +24V to lines 5 and 6 on the motor to release the brake before I "jog" the motor from the Panel Operator ?
I do not have anything plugged into CN1 as the manual indicates you can Jog the motor with out this. But since I am not using CN1 I have nothing connected to /BK+ and /BK-.
Any comments would be appreciated.
Thanks,
Kevin
[IMG] code is Off
Need Help!- Yaskawa SGDH drive (custom model Y49) bouseman Servo Motors and Drives 1 09-19-2010 04:35 PM
New Machine Build- 600mm Box bend brake (Finger Brake, pan Brake) RotarySMP Bending, Forging,Extrusion... 20 09-06-2010 10:56 AM
Yaskawa SGDH and SGDA servo motor/drive wiring questions rpseguin Servo Motors and Drives 62 12-02-2009 06:43 AM
New Machine Build- Z AXIS MOTOR WITH BRAKE Russ Shugg Servo Drives 3 10-26-2009 02:45 PM
Brake on quill drive required ? Paraprop Bridgeport and Hardinge Mills 2 04-16-2007 07:01 AM
