Old 11-09-2010, 12:42 PM
Khaled.Hosam is on a distinguished road
the encoders' wires itself
hii all, I bought a used DC motor with encoder, and I can't determine which of them is Vcc, ground, control.. can anyone helps me in this
thanx all
Old 11-09-2010, 01:57 PM
Al_The_Man's Avatar
One way is to see if you can identify any IC's on the encoder and determine which is the +5v and common and identify the appropriate wire colour, you can then power it up and determine signals by meter or 'scope.
Is there a motor or encoder make or model?
Old 11-09-2010, 02:10 PM
it got no IC on the motor as the encoder is embedded in it, but there are 3 colored wires from it, these colors are: yellow, brown and blue!!!
Old 11-09-2010, 02:27 PM
Al_The_Man's Avatar
It cannot be a quadrature encoder as at least 4 conductors are required.
A resolver requires 6, unless it is a digital tach of some kind?
Or is it the motor conductors you are trying to identify?
If it is a DC brushed motor, then one would have continuity to ground, the other two being the motor supply.
If it is a DCBL then the three conductors would have the same continuity/resistance between any two, and be the 3 phase stator winding.
Old 11-09-2010, 02:41 PM
I know the motor connection wires, what I wanna know is the connection of the encoder itself
Old 11-09-2010, 03:04 PM
Al_The_Man's Avatar
Can you post a photo of the encoder.
Pretty difficult to get a bi directional count with three wires, unless a serial encoder of some kind, even then it would be tricky!
Old 11-09-2010, 06:16 PM
mike_Kilroy is on a distinguished road
Ah, u say u bought a used DC motor..... so Al is prob right - prob is a TACH not an encoder at all. 2 wires plus a shield wire? tell us part no of motor so we can help. also ohm between all 3 wires and tell us what u get. from these 2 things we prob can help identify for u.
[IMG] code is Off
cheap absolute encoders? Oxymoron? Decent Incremental encoders? mattbesquare Benchtop Machines 15 09-08-2010 06:56 PM
need help id 8 wires 15mgtar Stepper Motors and Drives 6 07-30-2009 12:53 AM
8 Wires Steppers? kolias DIY-CNC Router Table Machines 8 07-18-2009 05:16 PM
What wires to use? studysession DIY-CNC Router Table Machines 2 02-21-2007 01:02 PM
Best way to keep wires out of the way CuttersCov DIY-CNC Router Table Machines 3 11-02-2006 08:40 PM
