11-02-2010, 09:29 PM
I have several of these motors.
COPAL
PN12-60119-01
I found this on the net. Re. the Copal motors extracted from those old Compaq 15/30 DLT
drives, part number LBT79-002 and possibly the -001 variant and others
with the 9-pin connector.
I've got them going they need +12 and +5V supplies (logic and
power). Here's the pinout.
Pin 1 = Motor drive enable 0=Off 1=On
Pin 2 = Gnd
Pin 3 = Direction control 0=CCW, 1=CW
Pin 4 = Output from sensor A 2.5V centre
Pin 5 = +12V In
Pin 6 = Gnd (internally connected to pin 2)
Pin 7 = Output from sensor B 2.5V centre
Pin 8 = Output from sendor C 2.5V centre
Pin 9 = +5V In
Connect a 1.5K resistor between pins 2 and 3 to ensure reliable
switching, else pin 3 floats at 1.7V and the motor is unstable.
It may be possible to pulse width modulate the motor enable (pin 1) to
get speed control.
-A |
I have one powered up and I measured the no load RPM at 2700. I'm not sure these are even worth playing around with but I should be able to learn about servos by playing with these.
When they are not bolted down they will kick off the table when switching direction. Obviously applying 5VDC to pin 1 is making the motor turn at full speed but I know for sure the RPM of these motors can be varied because I have used many a DLT drive at work over the year. They are obsolete now except for the very high end units, therefore the older units are easy to come by.
Is there a way for me to generate a PWM signal to test this motor?
Thanks for the help everyone! |
