Old 10-31-2010, 03:09 PM
Jackal66 is on a distinguished road
Question about AMC 30A8T servo drive
I am looking at some AMC servo drives on e-bay. Right now my Hurco is running servo mate 90vdc (12 continuous & 20peak amp) drives.
My plans are to do a retrofit soon. Either Mach3, Ajax control with Mach3, or all Ajax. Either way I want to keep a spare drive, and be able to change out a drive on just one axis ( That's why I don't want the Ajax drive module).
My question is, will the 30A8T work for what I am doing? Will the drive work with US digital encoders?< (I haven't purchased them, yet)
The "T" is supposedly a revised version. This drive has 80 vdc max & 30 amp peak with 15 amp continuous.
Here is link from amc:
http://www.a-m-c.com/download/datasheet/30a8.pdf
Thanks for all of the help,
JAckal
Everything is bio-degradable, if you run over it enough times with the lawnmower.
Old 10-31-2010, 03:28 PM
Al_The_Man's Avatar
These AMC drives are non-intelligent drives intended for the type of CNC system that closes the PID loop in the controller, with Mach you need a drive which each closes the PID loop and takes step direction input, the AMC are 10v analogue control.
Old 10-31-2010, 04:03 PM
Karl_T's Avatar
Karl_T is on a distinguished road
Have you considered EMC?
I just helped a fella with a servo machine. he used AMC amps and USdigital encoders. The refit worked out very well.
Karl
Old 10-31-2010, 06:02 PM
Thanks guys,
I have thought about EMC. Does the Ajax also require the same as MACH3?
JAckal
Old 10-31-2010, 06:12 PM
Al_The_Man's Avatar
From what I understand, Ajax uses Mach as a system.
Old 10-31-2010, 08:20 PM
So that makes it pretty much the same, unless you use the AJAX software. Which it may work the same way for feedback, etc.
Would these drives work with EMC???
Thanks,
JAckal
[IMG] code is Off
Question ? - What hobby CNC servo driver will drive a 12Volt DC motor FPV_GTp Servo Motors and Drives 25 10-27-2010 01:37 AM
Newbie- CNC Lathe - Servo direct drive or pulley drive? s76tools General Metal Working Machines 1 09-06-2009 11:17 AM
Fanuc Drive/Servo (A20B) Question Death Adder Fanuc 9 04-09-2008 09:42 AM
Brushless servo drive question jdholbrook Servo Motors and Drives 6 05-08-2006 07:27 PM
Newbie Servo Drive Question? chas Gecko Drives 0 03-31-2005 12:02 AM
