Old 09-27-2010, 01:04 AM
Meduza is on a distinguished road
Connecting BL30 to computer
Hello
I Bought a Harrison TU150 Lathe a while ago, and is planning on retrofitting it with Mach3 on a new computer, i am also about to fit a 17" inch touchscreen and propably a stainless steel keyboard with trackball.
The Servo drivers in it are Parker Digiplan BL30 and i wonder what i need to connect it to a computer paralell port, i have read the manual but i have only worked with Stepper systems before, so a little help to enter the servo world is needed
The Manual for BL30:
http://www.compumotor.com/manuals/BL/BL.pdf
A Picture of my lathe is attatched
Old 09-27-2010, 07:27 AM
vger's Avatar
vger is on a distinguished road
If you have the positioner board option with the drives as shown in Figure 2-3 of the manual, then your task may be fairly easy as the positioner board has clock and direction inputs. If not, then you will need an interface board to convert the digital step and direction outputs from Mach to the required analog signals for the drives.
Steve
Old 09-27-2010, 07:58 AM
No i do not have the BLX Positioner, what is mounted in my Lathe is two BL30L from 1993 and a 386SX based control system
Is there any ready-made step/dir to analog boards avalible to a ok price?
Old 09-29-2010, 01:44 AM
I have looked into the Mesa 5i20 and 7i33 boards and EMC2, is this the best way to do it?
I am on quite a strict budget, but want the best results possible...
[IMG] code is Off
What is the difference between an industrial computer and a normal computer? Apples Controller & Computer Solutions 9 09-18-2008 04:27 PM
Connecting rod ACME I.C. Engines 18 08-11-2007 12:09 PM
Connecting to Microscribe 3dx robinsoncr Digitizing and Laser Digitizing 4 03-03-2007 01:26 PM
connecting KrashKing405 Open Source Controller Boards 18 07-26-2006 05:30 PM
fast computer as server, slow computer as terminal replicapro Computers and Networking 1 07-01-2004 02:05 PM
