Old 09-02-2010, 11:36 AM
skippyfix is on a distinguished road
fanuc 5m servo
fanuc yellow cap servo
I have a victor vcenter 4 with a fanuc 10m controller, the x axes motor makes noise when you are moving it in the left position or in positive direction its does not make any noise going the other direction is there a parameter that I need to look at or is there a motor issue it has no drag on the ball screw . Please help
Old 09-02-2010, 11:38 AM
servo fanuc 5 m
today I turned my machine on to try and find why the x servo is making noise and it keeps having a alarm message Sv00 X Tachogenerator Disconnect,
SV013 X Improper V_Ready Off On the servo drive board a lite is on and beside the light is has GLS. Any Ideas
Old 09-02-2010, 12:12 PM
Al_The_Man's Avatar
Check tach and wiring, test tach for output by turning motor shaft and measure DC in both directions.
Old 09-02-2010, 03:42 PM
5m
could a bad velocity board cause a axes to make noise only in one direction?
Old 09-03-2010, 11:27 AM
PLEASE HELP
PLEASE HELP
Old 09-03-2010, 12:14 PM
Al_The_Man's Avatar
With Tachogenerator disconnect, did you test the tach??
Old 09-03-2010, 12:50 PM
5m
yes tach fine
[IMG] code is Off
can fanuc ac digital servo amplifiers be run by a controller other than fanuc? js412000 Servo Motors and Drives 5 03-09-2011 09:11 AM
Fanuc servo Al_The_Man Granite Devices 2 05-06-2008 02:58 PM
AMC amp with Fanuc servo Drew Fanuc 0 02-07-2007 01:54 PM
Fanuc AC Servo Help Babar Servo Motors and Drives 0 02-14-2006 12:34 PM
