Old 08-23-2010, 04:36 PM
Kingjamez is on a distinguished road
Servo resolution and Mach settings.
So I'm using gecko 320's with 250 count 4 line encoders. I have thompson .2" pitch ballscrews. When I tell Mach to move the table of my X3 mill, on the first thou of movement it moves about 1/4 thou. On the second thou of commanded movement it moves 1.75 thou so that it is in the correct place. This pattern repeats every 2 thou. Any idea why I'm seeing this behavior?
Next, when I put in the pulses per inch into Mach the correct setting is 8000, however from the specs above it looks to me like 5000 pulses would be correct. I have verified all of the specs above, so why is 8000 correct?
-Jim
Old 08-23-2010, 08:18 PM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
5000 is the correct number
Old 08-23-2010, 08:32 PM
When I have Mach 3 set to 8000, and ask it to go 1 inch, it goes 1 inch. I turned the ball screw by hand 5 turns, got 1 inch. I took apart the encoder and checked the jumper settings: 250. It has 4 wires going to a Gecko 320. What can I say? I'm baffled.
I've cut out parts that all came out the right size too.
Old 08-24-2010, 06:00 AM
GaryCorlew's Avatar
OK as long as it works, I am assuming they are amt encoders, which I also use, I looked at my documentation and if the encoders were held upside down and you looked at the switches, a setting of 400 would look like 250. Thats about the only explanation I can come up with. And needless to say I have been there, done that, got the tee shirt!
Old 08-24-2010, 06:03 AM
Well, that makes sense! Thanks for figuring that out, it was driving me nuts. I must have flipped over the encoder when I was reading the dip switches.
-Jim
[IMG] code is Off
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
Brushless servo resolution sp1nm0nkey Servo Motors and Drives 2 12-15-2007 05:47 PM
mach 3 settings najnielkp Viper Servo drives 4 10-08-2007 06:50 PM
Servo Resolution kiwiavi General Metal Working Machines 3 10-06-2007 04:14 PM
Mach 2 and settings tauscnc Commercial CNC Wood Routers 4 05-25-2005 09:05 AM
