Old 08-23-2010, 04:18 AM
manmardam is on a distinguished road
Yaskawa analog problem
i have a big problem with analog servo system .
in digital driver, when pin S-ON is active, and dont have any pulse in input, we see that shaft motor is Motionless and LOCK(if we want turn shaft with hand , we dont can)
but in analog drive, when i set 0V for input ,motor is motionless BUT i can turn shaft motor with hand.
why?
Amir
Old 09-18-2010, 12:59 PM
nobody ?
Old 09-18-2010, 05:13 PM
Mike Nash is on a distinguished road
In digital mode, the servo drive's outer control loop is position control and it will keep the encoder count from moving. In analog control the position loop is disabled and the outer loop is just the speed loop. It will try to hold zero speed, but will not try hold position at all. You would need an external position controller to hold position by varying the analog input to keep zero position error.
Old 09-19-2010, 12:31 AM
is it possible more explain about external position controller for analog driver(speed control)?
Amir
Old 09-19-2010, 07:43 PM
I'll have to leave that to someone else. If no one chimes in, you can google on Galil as an example of a manufacturer that makes motion controllers. Yaskawa also has them. As do others.
Old 09-26-2010, 12:28 PM
yates700 is on a distinguished road
Smile Call IES 678-341-8050
they help us with all of our repairs
678-341-8050 is their number or www.internationalelectronicsolutions.com
[IMG] code is Off
Yaskawa ac servo encoder problem Grubma Servo Motors and Drives 2 08-16-2009 12:24 AM
Yaskawa inverter problem anandhs Mazak, Mitsubishi, Mazatrol 4 12-21-2007 07:27 AM
Yaskawa Inverter Problem Mert-G Phase Converters and VFD 1 11-22-2007 10:09 AM
problem with Yaskawa V7 drive rebrumm Phase Converters and VFD 4 05-22-2006 04:40 PM
