Old 05-28-2005, 02:51 PM
CarveJunky is on a distinguished road
Talking Servo Specs...
I will be getting the sieg X3 machine some time in June or July. I will be doing a conversion on the mill. I have some parts with lots of curves that I need to make a lot of. I would like to try to start getting parts for the conversion but need a little help.
I called about the Clifton 30V servos, but they are out and will not be getting more... a great price on those. I have seem electro craft model #543 and #510 quite a bit. Does anyone know or have spec's on these? Anyone have any leads on any servo's priced like the Clifton's? I have also seen Ametek servo's, 30V, 40V, and 50V. I can't seem to find any Spec's tho. I would appreciate any numbers on those also.
TIA
Chuck
- www.carvejunky.com
- chuck@carvejunky.com
Old 05-28-2005, 03:37 PM
Al_The_Man's Avatar
I got the elecrocraft specs for someone in this forum before if you do a search.
Al
Old 05-28-2005, 04:59 PM
Al,
Are the EC E543 and E510 servo the same? I did another search as you suggested, and found the E543 specs, thanks. I couldn't find the E510 tho. Do you have anything on the Ametek drives?
Appreciate the help.
Chuck
Old 05-28-2005, 05:53 PM
ger21's Avatar
Here are a set of the clifton's, with the end machined for the encoders, and the encoders mounted and tested. http://cgi.ebay.com/ws/eBayISAPI.dll...518552936&rd=1
Old 05-31-2005, 08:03 AM
Gerry,
Thanks for the heads up on the motors. Unfortunately I didn't read the reply till Sun. morning and Auction was over, bummer. I found these:
http://www.lowcostcncretrofits.com/servo%20motors.html
Different place and lower price... Would these be suitable for the X3 driving ballscrews?
TIA
Chuck Clarke
[IMG] code is Off
Specs on an industrial sized servo DAB_Design Servo Motors and Drives 11 12-28-2006 10:35 PM
Specs on this servo JRoque Servo Motors and Drives 3 10-16-2006 08:26 AM
servo motor specs and help cowanrg Servo Motors and Drives 3 06-11-2005 06:11 PM
Where can I find Detail Specs Servo & Drive MEans ? Calico Servo Motors and Drives 1 02-28-2005 11:37 AM
where to get servo specs. miljnor Servo Motors and Drives 7 02-26-2005 01:39 AM
