| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
Hi, i have just purchased a set of Mitsubishi servos on ebay and have been searching for any info on connecting up the MR-C40A servo amp with step and direction signals from mach 3 and i came across a thread from 2008. Has anybody successfully got the servos running with a step and direction input from Mach ?. If so can you please tell me how to do it as my electronics knowledge is very limited and i fear i could have wasted a lot of money if there is no solution to the forward /reverse problem. Many thanks Charlie |
Were they the HC-PQ43-UE 400W servo motors? ATB Derek |
| I got 3 of the motors - no drives :-( The encoder is a serial link to the drive so i'll have to see if i can intercept the quadrature before it gets serialised or if that does not work, fit new encoders to the motor. I intend to use drives from Granite to complete the package. you might need some programming software from the (Mitsubushi) supplier to configure the drive ???? ATB Derek |
| Hi Derek, looking at the manual for the drives it does state that the drives will accept a pulse and direction signal amongst other things so i should theoretically be able to connect direct from the smoothstepper step and direction output using mach3 once i have worked out the right connections. As far as setting them up goes i believe that if you are using the motor that the drive was designed for it will automatically set the important parameters for you. There is software available so you can customise the settings and see what's going on on your pc but having had a quick look there is currently nothing for sale for my drives and i can't afford silly mitsubishi prices so i'll just fire them up and hope the auto set up function is as good as its word. As i am going to use them in a much simplified set up compared to many i may be ok. Have to find some encoder cables first as the connectors on the drives are now obsolete. Will let you know how i get on. Charlie |
| Hey there I've also bought few Mitsubishi Servomotors from eBay while ago,then I purchased dedicated servo drives for these motors. Mine are 200W ones(HC-PQ23-UE) and drives MR-C20A-UE. I am struggling with connecting the drives with breakout board thats has 5 outputs (GND, ENA, DIR, CLK, +5V) for each axis.I have all the connectors that are needed, but don't know which pins(SON,LSP,LSN,PP,PG,NP,NG,V5,SG,SD etc.) I should connect with breakout board. I made the encoder cables by myself instead of buying them from Mitsubishi for silly price and they work fine, no errors. So guys, if you find solution to this problem, please let me know. Thank you Mateusz |
| http://www.cnczone.com/forums/showth...ghlight=biesse i explained virtually full setup of mitsubishis in this post. took me ages to work them out but they are superb servos. read through it all, you should find the info you need.
__________________ so much to learn, so much to pass on. |
| Mitsubishi dc servo motor | jolulank | Servo Motors and Drives | 9 | 02-17-2011 07:32 PM |
| Need Mitsubishi Servo Motor | macona | Want To Buy...Need help! | 1 | 11-13-2010 02:32 AM |
| Need Help!- Mitsubishi servo drive | hotrob1 | General Electronics Discussion | 1 | 08-10-2009 08:00 AM |
| Mazak/Mitsubishi Servo | Jarwalcot | Mazak, Mitsubishi, Mazatrol | 3 | 11-03-2006 08:00 AM |
| mitsubishi mrh servo | rosli | Servo Motors and Drives | 1 | 07-19-2006 02:49 PM |
