Old 06-30-2010, 09:41 AM
Syphonics is on a distinguished road
Newbie needs help with servo
Hi all,
I am a green horn to servos. Previously i did with steppers but not with servos.
I have with me a Yaskawa SGMAS-A5A2A6C servo and a SGDL-01AS servopack.
I have connected the motor as in pic1. But have another 3 more black wires and a orange wire from the motor, which I do not know where it goes?
And the encoder, white green brown yellow wires where should they goes to?
Is there any good website or reference for me to do some research?
I downloaded the yaskawa manual but I am still confused.
Thanks for the help.
ID:	110128   Click image for larger version
Old 06-30-2010, 05:42 PM
ee_t is on a distinguished road
Other motor wires could be a 24V brake, is it easy to spin by hand?
The white block is likely encoder wires, which should connect to CN2.
http://www.spoerk.at/index/pdf/produ...I-Handbuch.pdf
Old 06-30-2010, 10:08 PM
Sorry for my ignorance and a newbie in servos.
I guess mine is a brake servo, i couldn't turn with hand. How do i connect the encoder wires to CN2? Which colour goes to which port?
How do i actually program or control the servos? Where should the pulses be input to?
I am using a Microchip PLC to control the servo.
Thank you
Old 07-02-2010, 06:56 AM
Anyone able to help me?
Old 07-07-2010, 10:13 AM
i am still lost. Anyone able to help me on my yaskawa setup?
Old 07-13-2010, 08:33 PM
Thank you
http://www.cnczone.com/forums/showthread.php?t=95952
http://www.mech.northwestern.edu/cou...ervomotors.htm
You would have to buy the CN2 mating connector, and solder the wires to it.
I think this is an analog control drive. So you would need an intermediate device to convert step/dir to analog.
Old 07-13-2010, 09:07 PM
currently i intend to use PLC to control the servo motor. Which port should the signal goes to?
Old 07-15-2010, 08:51 PM
CN1, torque or speed input.
Old 07-17-2010, 04:39 AM
after reading the manual, i have change my servo to the SGML series to match my SGDL servopack.
Currently when i wire my servo to the ON mode - pin 13 24V supply, the motor will run continuously. I input 5 v pulses into the CN1-3 it does gives some form of slow down to the servo, but still i am unable to control the direction and to stop or move the servo.
[IMG] code is Off
Newbie Qn on Servo Syphonics Servo Motors and Drives 9 03-09-2010 10:15 AM
Newbie question: servo vs. stepper rowan13 WoodWorking 10 05-21-2009 02:55 PM
newbie servo controller questions alphamail General Electronics Discussion 4 01-25-2007 03:18 PM
Newbie Servo Drive Question? chas Gecko Drives 0 03-31-2005 12:02 AM
newbie AC Servo question GalaticDan Servo Motors and Drives 3 10-30-2004 11:25 PM
