| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
I am not sure whether this forum is right place or not. Couple of days ago, I got KT-2525 I ordered from K2. I assembled and connected with my controller. I setup all axes and tried to move step motors. All 3 motors looked fine, but the issue happened when I tried to drive motor high frequency. When I tried to dirve motors around 3000Hz or more the motors just made "Why~~~ng" noise and not actually moved. but low freequence around 500Hz it worked. 500Hz / 200 step / 10 tpi * 60 sec = 15 ipm. Is this normal or what? I am using HobbyCNC controller configured 24V drive with upto 15A. My computer is about 133MHz pentium CPU. Step motors are purchased from HobbyCNC 200 oz motors. Show me the way |
| Lower your acceleration and your velocity, (in motor tuning menu) till you can get the motor to run at their top speed with-out missing pulses. Also check to see what your holding voltage on the hobbyCNC board is set to.
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| Which software are you using to drive the Hobby CNC board? Aside from checking the accell/decell, make sure your screws can rotate freely across the full travels of the axis. If the screw isn't prefectly aligned with the axis, binding is assured.
| Thank you for your reply. I am using TurboCNC software. Before the motors are installed they worked OK with around 6000Hz. But when they are equiped into CNC, the issue happened. I cannot say the screw rotates "Freely" but feels "tight". |
| working w/ iges file | tom@wave-l | Mastercam | 6 | 07-13-2005 12:57 PM |
| Machine working, Business & Website launched | Moondog | DIY-CNC Router Table Machines | 1 | 02-16-2005 04:25 AM |
| Mach 2 just stopped working | mikesos1 | Mach Software (ArtSoft software) | 2 | 02-09-2005 09:50 PM |
| Working with tombstone. | Per_N | General CAM Discussion | 1 | 01-05-2005 12:01 PM |
| Something I was working on when 22 | Hobbiest | CNCzone Club House | 1 | 03-13-2004 07:27 AM |
