Old 06-08-2010, 02:58 AM
marvinmfg is on a distinguished road
Post Having trouble understanding Haas MOCON/ Servo Amp Wiring
I've been working on an upgrade for my 2003 Haas TL-1. I want to install an industrial vector drive and a 10HP inverter duty motor as an upgrade to the standard 45 amp brushless PWM 3 phase servo drive that is currently running the spindle. I've got some crazy plan to change the gear ratio on the belt drive also to provide more torque, but I'm trying to get the electronics worked out first.
The problem I'm having is figuring out the pinouts from the MOCON board to the J2 connector (J3 on a vector drive). There is a pretty good schematic of a Haas vector drive posted on the net, but my understanding of logic circuits is limited, and a couple hours of tracing the circuits didn't really get me anywhere.
I've tried to pick up some of the signals with an oscilloscope, but they are all over the place time wise. I just can't tell what architecture Haas is using to control the drive. I'm pretty sure the encoder output is processed by the MOCON board, not by the servo amp directly.
The drive I want to use is a Saftronics C10 model 2015, which is pretty versatile. It will accept analog voltage or current based frequency commands and uses 2 or three wire switching to start and stop the motor.
Anybody have any ideas? Wiring diagrams?
[IMG] code is Off
3 Phase Motor Wiring Trouble PhoenixMetal General Electronics Discussion 14 12-12-2008 03:57 PM
Having trouble loading program using Mastercam"s Cimcov5 in my Haas Robert Timby Mastercam 3 01-19-2008 05:25 PM
Wiring trouble Smackre General Electronics Discussion 25 06-23-2007 03:32 AM
2000 Haas TRT-210-5-AX trouble 1cnchogger Haas Mills 4 04-02-2007 01:15 PM
Servo Trouble j-radkemachine Haas Mills 4 11-10-2006 12:49 PM
