Old 06-07-2010, 10:31 PM
MrArmyAnt is on a distinguished road
What size servos, gear reduction options, etc?
Looking at building a table that has over a 5ftx12ft travel, with a gecko 540 controller. Main use will be plasma and laser cutting, with possibly a dremel thrown in for cutting some mdf for speaker boxes and such.
Wwould way say its going to be moving about 70 pounds.
Controllers and all can be change, I just like how the 540 is all in one and seems to have a decent amount of support and following. I also like that a 4th controller is built in so I can use the plasma possibly as a tube notcher with a spinning axis.
Obviously not using ball screws.
3 of http://cgi.ebay.com/NEMA-23-Stepper-...4#ht_500wt_928 possibly work?
Old 06-11-2010, 12:33 PM
Iron-Man's Avatar
Iron-Man is on a distinguished road
VisualSizer - Professional Free Software
Check out the link below. It has free software for servo motor sizing etc.
I designed my servo reducers for a Sherline mill, although I did not need the software. Check out my work and others here; http://www.cnczone.com/forums/showthread.php?t=40940
Hope this helps.
Iron-Man
http://www.copperhillmedia.com/VisualSizer/index.html
[IMG] code is Off
Need help with gear reduction IQChallenged Linear and Rotary Motion 21 04-15-2009 10:36 AM
Need help with gear reduction IQChallenged Linear and Rotary Motion 0 04-03-2009 05:52 AM
Gear reduction set-up scrambled CNC Plasma and Waterjet Machines 7 05-05-2007 10:34 AM
what gear reduction are you using? stanglou CNC Plasma and Waterjet Machines 2 01-06-2006 05:21 PM
Gear reduction DragnsBane Stepper Motors and Drives 3 11-11-2004 05:36 AM
