| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
Hi! I have PMAC2-PS ISA controller (8 axes). Once the RED and GEEN LED light and communication to PC lost. According to manula - watchdog tripped. I can't check this controller. Please help me in: 1. Software to test it for integrity 2. The scheme for contacts. 3 How to repair hardware error 4. And so on... The PMAC-CPU is ASSY 602405. Ventage 1998 - 1999 Last edited by =aike=; 05-16-2010 at 08:35 AM. |
| I don't know if my PMAC is the same as yours, it looks the same, but here's how I reset my PMAC, apologies in advance if they're not the same, but it's worth a go: 1. Power up. 2. Get into the PMAC executive- on mine I change directory to PMAC and start the executive by typing PE. You should see a blue screen with "Found PMAC at specified address" if you do goto step 8, if it says "No PMAC found continue from step 3 below. 3. Exit PMAC and power down. 4. Locate position E51 on the board- insert a jumper here. 5. Power on and leave for 1 minute, then power down. 6. Remove the jumper at position E51. 7. Goto step 2 above. 8. Type $$$*** and press Enter twice. 9. Type P0..1023=0 and press Enter. 10. Type Q0..1023=0 and press Enter. 11. Type M0..1023->* end press Enter. 12. Type UNDEFINE ALL and press Enter. 13. Type WX:$786,$D,$45 and press Enter 14. Type SAVE and press Enter. 15. Type $$$ and press Enter. 16. Type I3=1 and press Enter. 17. Type I5=3 and press Enter. 18. Type SAVE and press Enter (wait till the cursor moves to the next line down. 19. Exit PMAC (press ESC then Y). [EDIT] Pin E51 on mine is located beneath the second blue plug from the left on your picture near the middle of the board.
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
| I've found the PE 1.6 software packet in my Sodick's computer hard drive. Hence I can now to connect to PMAC2-PC card and make programming. My Sodick's OS is Windows95. I tried to reinstall PMAC2 driver, but unfortunatly. In ControlPanel->NewHardware->OtherDevice I can't found any DeltaTau driver. Can you help me to send this driver for Windows95/98? So as I've read the pe32install.pdf, the process of installing hardware referenced to DeltaTau driver. |
| Sorry, but my system's even older than yours. I'm running under DOS. Can't you just run PE.EXE? what does it come up with if you do that? Anyone else got any ideas?
| My version 1s 1.14, so I don't know if this will help, but can you locate two pins on the board with "E51" written next to it in small white letters? 3. Exit PE and power down. 4. Locate position E51 on the board- insert a jumper here. 5. Power on and leave for 1 minute, then power down. 6. Remove the jumper at position E51. 7. Power up. Does windows see it now?
#10
| I like to upgrade these with new card and new pc so these can be reliable machine again. Any information you have about these machine upgrade will help. Thanks in advance - Surjit |
#11
| We do all kinds of Delta Tau repairs at ERD, Ltd. Visit our site at ERD Industrial Electronic Repair 99% in-house repair - 2 YEAR WARRANTY. Bill Clement, CET |
| Delta Tau Anyone | Al_The_Man | General CNC (Mill and Lathe) Control Software (NC) | 21 | 01-14-2010 01:08 PM |
| Need Help!- Problem with wiring limit switches to Delta Tau Pmac | jatchan | Servo Motors and Drives | 1 | 02-09-2009 07:41 AM |
| Delta Tau | cnc-it | General CNC (Mill and Lathe) Control Software (NC) | 3 | 04-29-2008 11:07 PM |
| Wye-delta, delta-wye configurations? | mackeym | Phase Converters and VFD | 10 | 09-27-2006 05:02 PM |
| delta tau | Jeremiah | Servo Motors and Drives | 9 | 06-22-2006 07:41 PM |
