| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
Hello I'm building amateur router. Some photos : http://www.cnc.info.pl/album_pic.htm?pic_id=3987 http://www.cnc.info.pl/album_pic.htm?pic_id=3957 I'm going to replace steppers (1Nm) with servo motors. Driver that i'm going to use is modified elm chan servo controller so i need dc motors. I will buy servo here http://www.akcesoria-cnc.pl but i have no idea what's the difference between servomotors http://www.akcesoria-cnc.pl/?menu=grupa&kat1=6 and dc motors with encoders http://www.akcesoria-cnc.pl/?menu=grupa&kat1=5 Should I use single channel encoder or dual channel ? Which one has quadrature (incremental) encoder ? How should i know ? Is it possible to use direct connection between motor and screw ? In this case servo motor will work at low speed (max 2000 rpm). How big servo should i use ? I need at least the same power as i've got now. 40W, 50W ,70W ? 100W ? Does it make sense ? What will be better : bigger steppers (2Nm) and better drivers (TB6560 instead of old L297 and L298) or servo motors. Now i have problems with loosing steps. A.R. |
| Single ended have 1 output/channel and differential 2 per. Differential uses RS422 line drivers and receivers for noise immunity, if your drives take this type, this is preferred, if the drives are single ended in, you can use either type encoder but do not get the noise immunity afforded by differential. Regards the motors it depends on whether is was due to poor torque performance curves on your stepper/drive combination or whether they were under rated. DC servo's tend to have max torque at zero rpm and remain fairly flat or dropping very slightly up to the max rated rpm. You would need to look at the torque curve spec on the motor. Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 05-11-2010 at 08:08 PM. |
| Need Help!- What kind of clamps should I use? | woox | DIY-CNC Router Table Machines | 4 | 01-07-2011 11:42 AM |
| Newbie- What kind of code is this? | zRob | CNC Plasma and Waterjet Machines | 3 | 11-24-2009 07:22 AM |
| What kind of machine i need? Help! | ChEmEkMaN | General Metal Working Machines | 5 | 06-21-2009 11:50 AM |
| What kind of cmm would you buy? | joecnc1234 | Polls | 3 | 04-07-2007 02:38 PM |
| What Kind Of CMM? | ajl6549 | Calibration & Measurement | 0 | 03-01-2007 11:57 AM |
