Old 04-12-2010, 09:05 PM
2_jammer is on a distinguished road
Question In over my head- again!
Hello All-
I have a small 3 axis router that uses stepper motors that I have been playing with for some time now, and I would like to upgrade to servos. So I bought some BLDC servos off the bay because I thought everyone made drives for these which I found out isn't exactly the case. So I went back to the 'bay and found a 3 axis BLDC driver made by AMC: BD30A8. What I didn't realize is the these are PWM driven? So now I'm not sure if these can even be used in my application. Can someone explain to me if I can use these, and if I can use them, what I need to do? Please see the pdf attachment. Thanks for your time.
Old 04-12-2010, 09:36 PM
Al_The_Man's Avatar
What type of command signal are you using? If step/dir then I think you are out of luck, these are PWM only.
Old 04-12-2010, 09:44 PM
Thanks for the fast response. I haven't worked that part out yet- I wanted to use a break out board. What is PWM and how would these driver boards be used- i.e. what application?
Old 04-12-2010, 09:46 PM
Al_The_Man's Avatar
Any controller that outputs a PWM signal, rather than step/dir or +-10v analogue.
Old 04-19-2010, 09:36 PM
I think I found a controller board to run these amps- Thanks for your help!
[IMG] code is Off
M Head Joe8888 Bridgeport and Hardinge Mills 0 02-23-2010 04:38 PM
Is this a J head? quadmasta Bridgeport and Hardinge Mills 4 02-08-2010 11:24 PM
90 DEG HEAD Get lucky G-Code Programing 3 06-29-2009 07:35 AM
In way over my head protrxrptr17 General Metalwork Discussion 18 11-05-2006 09:02 PM
BP with a M head? DennisCNC General Metalwork Discussion 3 02-22-2006 09:41 PM
