The tuned loop for servo systems is referred to as the PID loop, a search will bring you much info if you want to get more info on it, also a valuable resource is the instructional videos on the Galil Motion site if you want to learn about servo tuning.
Generally for two servo's to be used on the same axis requires the gearing feature of the controller, one axis (slave) is geared off the primary axis (master) encoder, Multicam mention they use a stand alone RISC/DSP controller which may imply they use closed loop gearing function in order to synchronize the dual axis.
Excess following error could well mean tuning, or alternatively a binding on the slave side, if this error is on the dual axis
LinkBack URL
About LinkBacks
