Old 03-30-2010, 08:02 PM
waleed alhadidi is on a distinguished road
Fanuc DC Servo Question
Hello everyone
I am new to servo control and all my experience is about steppers so forgive me for the stupid questions.
I have a machine with Fanuc DC servo motors and I want to control them with a servo drive that is compatible with mach3 (accepts pulse and signal inputs).
The motors don't have encoders but tachometers instead. So I'm thinking that I should replace the tachometers with encoders.
The question is : Is this possible?
And If yes what drive is and encoder are suitable?
And can any DC drive control any dc motor?
The motor is A06B-0645-B081 , 8.8N.m , 2000 rpm , 140V , 14.2A permanent magnet.
Thanks in advance,
Waleed.
Old 03-31-2010, 08:02 PM
Al_The_Man's Avatar
Modern drives do not use the tachometer, there are drives out there that should work.
I believe Larkin is developing a higher current drive.
You will have to replace the tach with encoders.
DC motors are the most flexible out there as they do not need external commutation.
Old 04-01-2010, 09:38 AM
Thanks Al.
Do you mean the answer for this question is YES?
What is suitable for the motor? Viper 200 or Viper 250?
And what type of encoder do I have to buy?
Old 04-01-2010, 09:48 AM
Al_The_Man's Avatar
Yes, You can even use many BLDC drives to drive a brushed DC motor, I would send a PM direct to Larry (Larken) and run it by him, I have not used these drives myself.
TTL Differential type encoders are the way to go if the drive accepts them.
Old 04-01-2010, 06:36 PM
Thanks Al
These information are very helpful
Old 05-29-2010, 09:56 PM
Just one more silly question.
Is the (permanent magnet)=(brushless) ?
and what type is my fanuc motor ?
Because the drives are either (brushed) or (brushless) and the only thing I know about my motor is that it is permanent magnet.
Old 05-29-2010, 10:30 PM
Al_The_Man's Avatar
Both Brush and brushless have permanent magnet the brushed have the magnetic field stator the brushless P.M. rotor.
Fanuc DC brushed motors usually have a yellow cap, the AC Brushless have a red cap.
Old 05-29-2010, 10:41 PM
but my motor has a black cap. But I can tell you it has only 2 power wires would that be brushed?
Old 05-29-2010, 10:52 PM
and it is written on it (EXCIT PERM MAGNET)
Old 05-29-2010, 11:08 PM
OMG I found in this link http://fanuc.cnc-electronics.com/motor-encoder.html that black cap motors may be AC or DC.
So how should I know AC or DC? Does the two power wires make any clue? Does that mean it is DC brushed?
Old 05-30-2010, 10:01 AM
Al_The_Man's Avatar
Two wires usually indicate DC brushed, but if you look at the motor you can readily see the brush holder caps that unscrew.
You may have 4 or 8.
The very early black cap DC were Gettys motors that Fanuc initially used.
  #12   Ban this user!
Old 05-30-2010, 11:03 AM
Thanks Al now it's clear. I'll see the brushes.
[IMG] code is Off
can fanuc ac digital servo amplifiers be run by a controller other than fanuc? js412000 Servo Motors and Drives 5 03-09-2011 09:11 AM
Another quick fanuc servo question. RP Designs Servo Motors and Drives 1 08-31-2009 01:01 PM
Fanuc Drive/Servo (A20B) Question Death Adder Fanuc 9 04-09-2008 09:42 AM
Fanuc servo question... Jonne Fanuc 4 11-20-2007 04:42 PM
Fanuc 0M servo alarm question geeserteg Fanuc 3 02-22-2007 11:03 AM
