Old 03-26-2010, 03:35 PM
Rooney is on a distinguished road
Steppers and servos together?
I did a search and could not find this subject.
I'm running a C10 breakout board with 3 steppers right now and I'm looking at adding a rotary axis.
Can I run stepper motors and servo motors off of the same breakout board? I see that both kits from Keling come with the same board. Just wondering if they can share it.
Old 03-26-2010, 04:40 PM
Bachward Child is on a distinguished road
As long as the servo drive has a step/dir interface like the stepper drives then it shouldnt be a problem.
Assuming, that is, that your BOB has enough outputs.
Old 03-27-2010, 05:31 PM
Could be...
that I don't understand closed loop enough to ask an intelligent question. But, I have an additional parallel port that will jump off of the existing one I am using. That being said, I do still have additional outputs on the current c10 I am using. As long as I still have available inputs, will I still be able to have position feedback?
Old 03-27-2010, 05:45 PM
Al_The_Man's Avatar
As far as Mach is concerned the output is the same whether servo or stepper, you just use the applicable drive and motor.
The position feedback with Mach is to the drive.
Old 03-28-2010, 09:58 AM
If I am understanding correctly, Mach only knows what it is telling the drive. Position feedback and any necessary position corrections happen within the drive?
Old 03-28-2010, 10:31 AM
Al_The_Man's Avatar
Yes, with the parallel port version, a bit different if you are using the Galil card add on.
Old 03-29-2010, 07:23 AM
Thanks, All.
Rooney
[IMG] code is Off
Do you use steppers or servos ????? KEYTEEM Polls 34 12-31-2010 08:29 AM
Newbie- steppers vs servos accuracymark Benchtop Machines 58 01-18-2009 06:04 AM
Servos vs Steppers? ZenOrbit Canadian Club House 1 02-05-2008 07:20 PM
Steppers and Servos... ger21 FAQ of CNC Machine building 1 02-23-2006 09:45 PM
steppers vs. servos twombo Machine Problems, Solutions , Wireless DNC, serial port 10 06-10-2003 02:43 PM
