Old 03-24-2010, 09:42 AM
gabedrummin is on a distinguished road
DRIVER QUESTION
Hi all I have a maxnc control It has steppers with encoders . The motors are 65 volts at 2.3 amps 70 watts . Is there a good driver on the market that I could use and still keep the motor and encoder setup .Thanks for all your help
Old 03-25-2010, 10:00 AM
Larken is on a distinguished road
The encoder is only a 200 count single ended one. Not much good for a closed loop system, unless you are only running full step.
Manufacturer of CNC routers and Viper Servo Drives
www.LarkenCNC.com and www.Viperservo.com
[IMG] code is Off
Need Help!- Quick driver question hearld DIY-CNC Router Table Machines 6 04-21-2009 08:59 AM
Problem- Driver test question woodr004 Machines running Mach Software 5 01-12-2009 10:12 AM
Stepper driver question ? msnarouz Stepper Motors and Drives 0 10-29-2006 08:16 AM
M6R5 driver question Bill Davis Stepper Motors and Drives 1 02-17-2006 06:03 PM
