| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
Hello, I am looking to see if anyone knows what encoders are compatible with the PICO conversion board? http://pico-systems.com/oscrc4/catal...products_id=29 I have a PINOUT for a A860-0315-T101 and I know it will work, But my question is what else is compatible. Manly this one, A860-0360-T001 Is there anywhere I can get a model number explanation? Thanks |
Actually, it uses the proprietary signals only during the first revolution of the motor, once the index pulse has come around, it uses the quadrature signals to produce more accurate commutation signals. What motors are these encoders on? I might have more luck tracking down the compatibility from the motor number. The newer series have serial encoder output, usually with a 10-pin connector on the motor. But, I see they also have used a 17-pin connector on some, but the connector is a MS3106 type. I don't have a converter for the Fanuc serial encoders yet, but if I can get one of these motors, I'd like to make one for them. Jon |
| Jon |
| Beware of encoders A860-0310-T021/T022/T023, They have the C1-C8 signals but are low level sinewave encoder. Al.
| Pico Systems Resolver Converter | charliegolf | Pico Systems Motion Control Products | 10 | 08-19-2009 09:21 PM |
| Pico systems closed loop servo boards..... | pete from TN | Benchtop Machines | 25 | 08-09-2009 08:26 PM |
| Need Help!- Need advice from Expert! P/N compatible Fanuc 6M and 6T | cjchands | Fanuc | 2 | 02-04-2009 04:47 PM |
| Axima Classic Controller compatible with Fanuc Velocity Control Unit? | DNB | General Electronics Discussion | 2 | 08-18-2007 04:45 PM |
| which post is compatible with Fanuc 6M? | bowber | Post Processor Files | 1 | 11-03-2006 08:53 AM |
