Results 1 to 5 of 5
Thread: Driving a 4 pole ac servo with a 6 pole drive
    Feb 2004
    Edison, NJ
    I was wondering if it is at all possible to drive a 4 pole ac servo with a drive designed for a 6 pole motor. I have everything all hooked up and the motor just jitters. The motor is a baldor bsm80b ac servo, and the drive is an emerson fx-316 drive. The drive can't be set up for 4 poles as far as I know. Is there any trick to fool the drive?? I don't need any positional accuracy. Just want it to spin.
    Dec 2003
    Usually the drive is set for 60 degree phasing or 120 deg phasing and the commutation is taken care of by the hall effect or resolver sensor. Do you have the phasing right (motor phases) ?
    Al
    Feb 2004
    Edison, NJ
    I think I have the phasing right. Is there any way to check this? The servo leads are U,V,W, and R,S,T on the drive. Don't think they will match in order since they are different manuf.
    Dec 2003
    What type of feedback do the Baldor use? Hall effect switches? they need to be phased correctly with the motor windings.
    Feb 2004
    Edison, NJ
    They use resolver feedback, and I aligned it as they recomend(emerson) for their drive. Wired the phases up all 6 different ways and still nothing.
    1. Using surplus servo motors as spindle drive
      By Swede in forum Servo Motors and Drives
      Last Post: 03-16-2008, 09:05 AM
    2. Where can I find Detail Specs Servo & Drive MEans ?
      By Calico in forum Servo Motors and Drives
      Last Post: 02-28-2005, 12:37 PM
    3. Brushed servo drive replacement
      By motordude in forum General Electronics Discussion
      Last Post: 07-06-2004, 02:09 PM
    4. Cheap 0 Clifton and servo drive selection (advice needed)
      By Konstantin in forum General Electronics Discussion
      Last Post: 04-14-2004, 11:21 AM
    5. R90H Servo Drive
      By Verboten in forum Servo Drives
      Last Post: 03-30-2004, 10:10 PM
