Old 03-19-2010, 04:21 AM
marq_torque's Avatar
marq_torque is on a distinguished road
Question Fanuc servo and spindle control with mach3
Hello every one,
Is there any guy around who used fanuc servo with mach3
I am very newer to fanuc systems. i had never used it before or converted!
there are surplus servo drives and spindle control from scratch machine.
the fanuc CNC control is old and i am going to replace to accept mach3's raw pulse and direction.
for Fanuc servos and spindle system model nos. found from the cabinet
1) A06B-6079-H203, 2.5Kw
2) A06B-6081-h106, 9.4Kw
3) a06b-6082-H211#512, 13.2Kw
Old 03-23-2010, 09:28 AM
marzetti is on a distinguished road
To get full benefit of those servos I would suggest EMC2 rather than Mach as you will able to create a true closed loop system. Pico systems has reasonably priced boards that can tie everything together. http://pico-systems.com/oscrc4/catal...ex.php?cPath=4
Old 03-23-2010, 02:37 PM
Question Any one help me for configuration with mach3!!!
marzetti Thanks for your reply,
But i am in confusion for perticular that model of drives! i tried googling but not found any satisfactory detailed info!!!
i needed help on finding connection diagram, parameter settings, tuning etc, etc... like adapting newer servo/VFD to controller soft. like mach 3 or any other. there is no issue on reliability for mach3. i don't know about Linux CNC. but have interest to try out EMC!!!
:Cheers:
:Cheers:
[IMG] code is Off
mach3 spindle control on nm-200 urbanimports02 Novakon Systems 2 01-19-2010 09:33 AM
Setting up Spindle Control in mach3 UKRobotics Mach Mill 2 10-18-2009 04:34 PM
Mach3 spindle control of Boxford 260 VMC jwhitley Benchtop Machines 1 09-09-2008 12:21 PM
VSD-A Spindle control in MACH3? mkuivamaki Granite Devices 8 09-08-2008 02:09 PM
SX3 spindle speed control with Mach3 bbox Benchtop Machines 47 07-05-2008 05:15 PM
