Old 03-19-2010, 01:33 AM
golfietis is on a distinguished road
Pacific Scientific R33
I have got 2 Pacsci servo motors. They are R33 motors. Unfortunately I was not able to find out what type of encoder they have. I have emailed Pacsci support, unfortunately have got no answer...
Motors model number is R33SSNC-SS-NS-NC-02.
I understand that they have no secondary feedback device, no shaft seal. But feedback device "SS" is not in the documentation provided by pacsci.
Also they say:
R30 Series Motor - 3.25" width/height (square frame)
4-pole synchronous servomotors
Samarium-cobalt permanent magnets for maximum torque-to-inertia without demagnetization
Low rotor inertia for rapid accel/decel
240V ac, 320V dc bus operation
Anti-cog stator design
Rated speeds to 7,000 RPM
What does this 240 AC and 320V DC means? Can I connect it to AC or DC driver?
Old 03-19-2010, 01:20 PM
Matt Adams is on a distinguished road
Post
I work for a PacSci distributor. From the part number, this is a brushless DC motor that was custom for an OEM.
Since it doesn't have standard feedback (resolver), i wouldn't be surprised if it had Sine Encoder feedback.
240 volts AC through a rectifier yields 325 VDC. This motor can handle a servo drive whose voltage is either up to 240 VAC.
Good luck,
Matt
Matt Adams - Motion Control Application Engineer
IMAC Motion Control - Elgin, IL
Old 03-19-2010, 01:58 PM
Al_The_Man's Avatar
It appears from the data I have that the primary feedback only is a 8 pin connector that would be a Tachsyn, Resolver or Hall sensors.
You most likely could tell by resistance check, if fairly low resistance from A-C (cosine) and same from B-D (sine), then this should be the result for the resolver, if a reading between C-D-E is the same then it could be a Tachsyn, the Hall effect is A+ve B-ve C D E is H1,H2,H3
If a 17 pin connector then there will also be encoder output. The pin out is the same pin letter for the commutation..
Old 03-19-2010, 02:49 PM
Thanks guys for answers....
I will take picture of the connectors and feedback device tomorow. When I looked at it, it (feedback device) looked similar to RC brushless motor...
Also, what type of pacsci drive should I look for these motors? Documentation looks quite confusing for me...
Or I might look at Granite Devices drives... But they are 160 VDC only...
Old 03-19-2010, 02:54 PM
Post
The first step is to find the feedback type. There are only a few drives out there that can handle a wide variety of feedback devices within a single part number. You'll be really sad if you buy a drive that can only handle incremental encoder feedback with halls and you're stuck with a resolver or sine encoder!
Matt
Old 03-19-2010, 02:57 PM
Al_The_Man's Avatar
The type of feedback decide the nature of the drive required, BLDC, AC sinusoidal etc.
Also depends on what is the nature of the control signal, analogue, step/dir etc.
Old 03-20-2010, 12:56 PM
Some photos of my motors
ID:	103307   Click image for larger version
ID:	103308   Click image for larger version
ID:	103309   Click image for larger version
Old 03-20-2010, 01:18 PM
Al_The_Man's Avatar
Well it looks like you do not have an encoder, either a Tachsyn or resolver, I suspect the latter by the look of it, the drives that use these typically are AC sinusoidal and extrapolate and encoder signal from the Resolver phases.
You either need a drive that is compatible with this particular resolver or fit an encoder with hall tracks for a four pole motor.
Old 03-20-2010, 02:04 PM
Thanks Al
Looks like I will need encoders. This will be best way..
[IMG] code is Off
Need Help!- PACIFIC SCIENTIFIC syeraven General Electronics Discussion 0 09-23-2009 08:00 PM
Need Help!- NEED HELP with Pacific Scientific motor ???? autorouter34 Stepper Motors and Drives 0 09-11-2008 05:21 PM
Centent and Pacific Scientific IN-WondeR Stepper Motors and Drives 5 01-21-2008 09:46 AM
Pacific Scientific 750 controler cyclops1 General Electronics Discussion 1 12-09-2007 09:57 PM
Pacific Scientific 6510 Drive marshall1 Stepper Motors and Drives 1 03-29-2006 03:27 AM
