| Servo Drives Discuss all Rutex servo drives and get direct support! |
| I am finally getting back to a old project to retrofit a huge Sharnoa knee mill with Mach 3. In reviewing all I had planned, I found one item that I hadn't figured out. The original Z axis drive motor has a built in brake...how does that work? I forgot to mention that I will be using Rutex 2020 axis drives on all axis'. Do I just remove the brake unit, or is there some way to operate it from the pc/mach3/rutex drives? |
| Normally an axis brake is picked up when the drives are made active, you could operate it when the E-stop relay is picked up. Al.
| Thanks for the reply...I kinda thought that is how it would work, but I want to check with someone smarter and more experienced than I am. Now, maybe after being "distracted" by other business efforts I can get back to this project. I had purchased everything I needed and I got stacks of SS relays and motor starters from other projects. Maybe I can get to work and actually "use" some of the treasures I've collected over the years. Thanks again. |
| Hi Russ The question of brakes on servo systems is one that has a number of solutions that have evolved to suit different applications. For some the use of the commercial friction brake is not viable either on the grounds of cost or weight. A simple low cost 'brake' can be provided by a relay or solid state switch to short the windings. This is not perfect as there will be some movement. The movement is less than half the full step angle. The application of a steady DC supply has also been used where for safety reasons the stepper has to be removed from automated controls for safety reasons. Both the application of the short circuit condition or the use of a steady state DC supply could obviously be interlocked with the machine guards for additional operator safety. The application of DC to the windings of an AC motor woll bring it to rest but offers no motion resistance when the spindle has stopped turning. This is often used where there are high speed fans with air filters that need to be serviced but when removed leave the blades exposed. A simple rectifier and interlock switch does the trick for these types of application and depending on the type of spindle motor might help with rapid tool changes. I have tried to find out more about the motors you have and think they are 200 steps per rev. You might like to try connecting all the motor leads together and try and rotate the spindle as this may well be enough to stop the ball screw rotating under the static load. Hope this helps keep it simple. On very big servo systems in addition to a brake there is often a pin that is inserted to make sure there is no unwanted motion when the drives are being serviced. The safety pin being sized to cause the drive components to fail but leave the load suspended safely. I raise these alternatives as there are a lot of simple servos out there that might be candidates for a retrospective mod. Regards Pat |
| Tags |
| mach3, rutex, z axis brake |
| 9 axis press brake help | cnc metalcraft | Bending, Forging,Extrusion... | 1 | 10-31-2011 10:55 PM |
| New Machine Build- 600mm Box bend brake (Finger Brake, pan Brake) | RotarySMP | Bending, Forging,Extrusion... | 20 | 09-06-2010 10:56 AM |
| adjusting z axis jib with brake | 300sniper | Tormach PCNC | 5 | 08-19-2008 07:19 PM |
| A axis brake issue | nervis1 | Post Processors for MC | 2 | 04-17-2006 08:46 PM |
| Parallel Relay Board & Z-motor brake issue | Liv2fish2 | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 02-06-2006 11:35 AM |
