Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Rutex Products > Servo Drives
Servo Drives Discuss all Rutex servo drives and get direct support!
Old 03-13-2005, 11:24 PM
MMT MMT is offline
MMT is on a distinguished road
Control Cabinet almost finished.
The motors and 4th axis drive drive should be here on 14 march. I still need to put in a 24vdc power supply, and that should be about it. Any question, critique's, or suggestions?
Old 03-14-2005, 01:24 AM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
man that is a monster transformer! and I noticed your relay is that three phase? love those rutex boards man they are so compact.
are the three smaller transformers for the motors or what?
Old 03-14-2005, 04:09 PM
MMT MMT is offline
That monster runs all 4 motors @ 120VDC. The three smaller ones are inductors for each motor. Rutex has just advised me not to use them, so they will be removed. Yes the larger relay is 3 PHase for the 3 hp spindle motor, and the smaller one is for coolant pump. Today I got the 24 power supply for the relays installed. I put the relay coils on a separate toggles with led's for the coolant and spindle so I can disable them to "dry run". Also installed a panel locking disconnect switch for the main power. So far I have just under $2000.00 in the control. That includes the motors, and everything in the pic. The only items that I did not purchase wer the cabinet the monster power supply and the capacitor.
I own a machine shop with several cnc's and have done some very basic troubleshooting, but have never done any kind of electronic work at all. I hope all this goes well. Kent
Old 03-15-2005, 02:08 AM
miljnor's Avatar
S.N.A.F.U.
I wasn't aware that you needed to transform 120v ac to 120vdc unless of corse your not in U.S. then i would say nevermind
there are probably alot of shop owners in this forum. I own a medium small company (getting bigger monthly) and I am just doing this for a hobby! (ya, I am a sick bastard! )
just started this stuff so I could say keep from being board in the 2 or 3 seconds of spare time I have. and to brush up on my electronics (which I have forgoten almost everything)
Old 03-15-2005, 05:02 PM
MMT MMT is offline
AC or DC depends on the servo motor. AC motors and the electronics to drive them are much more expensive. My motors just happen to run at 120VDC. You can get servo motors in a wide variety of voltages.
Old 03-19-2005, 04:40 PM
johnd is on a distinguished road
Could you please let me know where you got your formula or procedure to size your power supply? Is it basically the same route as for sizing a power supply for a stepper system? Thanks you again for the help.
JohnD.
Old 03-19-2005, 05:17 PM
Al_The_Man's Avatar
You would need an isolation transformer even if you want to provide 120vac into the power supply as generally you would make the DC common to ground, if you did this from straight off the 120v supply you would blow the rectifier due to one side of the AC also being grounded.
Al
G-Code to DXF WayneHill OpenSource Software 189 01-30-2012 11:15 AM
Stepper control software suggestions jlawren6 General CAM Discussion 6 05-21-2011 06:42 AM
Visual Basic Controller Project dwwright Visual Basic 29 02-14-2011 02:24 PM
CNC Glossary CNCadmin CNCzone Club House 17 03-09-2008 04:08 PM
How do you like my control cabinet? ESjaavik CNCzone Club House 8 06-11-2004 02:23 AM
