Page 1 of 2 12 LastLast
Results 1 to 12 of 19
Thread: Could it be so that my servo doesn't need Ki and Kd?
    Mar 2004
    Sweden
    I'm tuning a bunch of R990H cards I never used with a bunch of Yaskawa/Nidec minertia servo's (cute a powerful small things, by the way). They are rated to 65 V but now when tuning I'm only using 12 V.
    When test running the setup with R990H.exe's tune command, I get a really steap and steady curve up to top of the graph and only a overshoot of 14 steps. That is with following config:
    Kp: 6016
    Ki: 0
    Kd: 0
    But when I read the suggestions in the nice howto at http://www.eaglemotion.com/home/R9xHbdi/pg5.htm it seems that a servo config should have a Ki-dampening and pretty much Kd. If I test with values closer to the suggestion:
    Kp: 6016
    Ki: 150
    Kd: 4000
    The curve becomes a lot more bouncy and I have an overshoot at 80-120 steps.
    To me, the first config and graph looks a lot better, but is it normal or okay to run with no Ki/Kd?
    Regards,
    Sven
    H.O
    H.O is offline
    Jul 2007
    Sweden
    Hi Sven,
    No Ki or Kd sounds a bit strange. Are you tuning without any load on the motors? Without Ki and Kd the "stiffness" of the motor will be fairly low, I think.
    /Henrik.
    Mar 2004
    Sweden
    Yes, no load. They are on my desk. The servos are really compact and I know some says they are a little odd to run, but no Ki/Kd at all and a perfect tune is strange to me too.
    H.O
    H.O is offline
    Jul 2007
    Sweden
    Try loading them just a bit with your fingers or whatever, without any Ki they probably won't reach the target position. Also, when the motor is stationary at try deflecting the shaft, without Ki and Kd it will probably feel "soft and sluggish". But if it works to your satisfaction without Ki and Kd then what the heck...if it ain't broken..... ;-)
    /Henrik.
    Mar 2004
    Sweden
    Check it out.
    EDIT: Hmm... Will the characteristic be different when I'm feeding with max voltage? I used 12 V only now, and they're supposed to get 65.
    Attached Thumbnails Attached Thumbnails Could it be so that my servo doesn't need Ki and Kd?-img_4779_modified_gimp_image_editor_.jpg   Could it be so that my servo doesn't need Ki and Kd?-img_4780_modified_gimp_image_editor_.jpg   Could it be so that my servo doesn't need Ki and Kd?-img_4781_modified_gimp_image_editor_.jpg
    Mar 2004
    Sweden
    Well, everything seems fine so... <swedish>...vad tusan. Jag k&#246;r p&#229; det. </swedish>
    H.O
    H.O is offline
    Jul 2007
    Sweden
    That sure looks like a near perfect step-response! You will definetly need to retune after raising the voltage since that is basically the same as raising the gain (Kp). If it changes the impact on the "no Ki or Kd issue" is hard to say, I guess the only way to know for sure is to try it.
    Nice compact motors there, what are you going to use them for?
    /Henrik.
    Mar 2004
    Sweden
    On a steel monster.
    Attached Thumbnails Attached Thumbnails Could it be so that my servo doesn't need Ki and Kd?-img_4769_gimped_.jpg
    Mar 2004
    Sweden
    I ended up with Kp at 4000 and still no Ki and Kd. Got a sampling rate less than 0.3 seconds. Pretty awsome acceleration on a servo that small. A lot more overshoot though, but I believe it's a minor issue.
    H.O
    H.O is offline
    Jul 2007
    Sweden
    Hi Sven,
    Try adding som differential gain (Kd) then, it should decrease that overshoot. When you add Kd you may need to add even more Kp though.
    Registered Karl_T's Avatar
    Mar 2004
    Dassel,MN,USA
    Quote Originally Posted by svenakela View Post
    But when I read the suggestions in the nice howto at http://www.eaglemotion.com/home/R9xHbdi/pg5.htm it seems that a servo config should have a Ki-dampening and pretty much Kd. If I test with ...
    I went to this page. Nicest explanation of P, I, and D I ever seen.
    5.1.1. Kp – proportional gain. Proportional gain is directly proportional to the torque. It is the main force in the whole PID loop. The kp provides a multiplier for the position error between the commanded position (from the CNC control) and the counter which tracks the feedback from the encoder.
    5.1.2. Kd – differential gain. It is like oil in a shock absorber. It makes the servo settle in the desired velocity.
    5.1.3. Ki – integral gain. It is like a flywheel in a toy car. You have to push it harder (more Kp) to move it, but it runs smoother then a toy car without a flywheel. The I part of the PID filter integrates the following error and this integral is directly added to the P term and keeps the following error small during the motion or in steady condition. In fact, correctly tuned Ki can keep the following error within +/- 1 encoder count during constant velocity motion (or in steady condition) while the motor can deliver full torque. The other great advantage of Ki is that it can make from a simple trapezoid velocity profile a profile very similar to a typical “S” profile. A trapezoid velocity profile is when the motor acceleration is constant (an increment of velocity) until it reaches the desired velocity. In S profile, the acceleration at the start is rather low, then it exponentially goes up till it reaches the maximum possible acceleration. Then, just before reaching the desired velocity the acceleration gradually decreases. You can see the typical S velocity profile on the faces of the astronauts in the space rocket while taking of.
    BTW, I have some servos in a Hardinge HNC that liked almost no I and D
    Mar 2004
    Sweden
    Quote Originally Posted by H.O View Post
    Hi Sven,
    Nope, it didn't help (I tried that). The overshoot was still the same but with a lot more oscillation before the servo settled. With no Kd the curve is still the best.
    Maybe I'll try with more Ki later, but for now I think I'll leave it as it is.
    --S
  • Page 1 of 2 12 LastLast
    1. Need Help!- 'Jumpy' servo motion; NUM servo and drive.
      By ralph@nes in forum Servo Motors and Drives
      Last Post: 08-24-2010, 11:34 AM
    2. Matching a servo drive to a servo
      By 69owb in forum Servo Motors and Drives
      Last Post: 02-03-2009, 10:00 PM
    3. Sell Servo Motor, Servo Drive by GSKcnc.com from China
      By salecnc@hotmail in forum Product and Manufacturer Announcements
      Last Post: 06-03-2008, 03:55 PM
    4. Pluto Servo - Motors won't servo correctly????
      By TZak in forum LinuxCNC (formerly EMC2)
      Last Post: 01-10-2008, 03:34 PM
    5. Servo drive / Servo Amplifier
      By Ken_Shea in forum Servo Motors and Drives
      Last Post: 07-10-2007, 06:12 PM
