Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Rutex Products > Servo Drives
Servo Drives Discuss all Rutex servo drives and get direct support!
Old 01-17-2009, 05:39 AM
aogonzalez is on a distinguished road
Bridgeport DX-32 (Explorer I) / Conversion
Hello, my name is Alejandro I'm new in the group. I need retorfit an Bridgeport Explorer I.
The servomotors are: SEM MT30M4-28, 4000RPM, 26lb/in, 112V 65A,
they work with analog servo-amplifier at 100VDC of DC BUS.
I have two way:
1- adapt analog amplifier to digital interface STEP/DIR with Skyko. (the problem is skyko are discontinued product and I don't know/find similar product).
or
2- put new drives (the problem is the voltage of opeartion 100VDC, all of drives work maximum 80VDC).
Please send me yours commentaries...
Thanks in advanced, regards
Alejandro Gonzalez
Old 01-29-2009, 07:00 PM
Larken is on a distinguished road
The Viper 200 drive will drive those motors fine. Others have done the retrofit on the same machine.
Manufacturer of CNC routers and Viper Servo Drives
www.LarkenCNC.com and www.Viperservo.com
Old 01-30-2009, 02:05 AM
NC Cams is on a distinguished road
WHy retrofit? Problems with DX32?
What are you doing with old DX32 stuff?
need help on my bridgeport conversion pham1129 Knee Vertical Mills 3 07-07-2008 11:24 PM
BridgePort Explorer X-26 Gear Range Issue Lesleh Bridgeport and Hardinge Mills 2 11-30-2005 07:27 PM
Bridgeport cnc conversion? Bryscnc Bridgeport and Hardinge Mills 10 03-10-2005 07:07 PM
Bridgeport Explorer CNCs arsenix Bridgeport and Hardinge Mills 9 02-10-2005 06:28 PM
