| Servo Drives Discuss all Rutex servo drives and get direct support! |
| Hi, can anyone out there help? i have a Shibaura VMC4 by Toshiba circa 1983 and it has blown Transistors (2SD646A) on the spindle drive. i have looked all over for them or the equivalents. thanks
__________________ BR |
| If you get stuck you may want to look in the Motorola range of types MJ or MJH there is a source in the UK http://www.dialelec.com/index.html It seems that they may be high voltage NPN darlingtons TO3?, if you do not need the high voltage look at something lower like MJ11030 etc. Good luck. Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
Al
| 2SD646 NPN switching transistor VCBO 600v VEBO 5v Ic 50A Pc 400W(Tc=25゚C) Tj 150 degrees centegrade hFE >150 fab/ft* 5 Mhz Cob 600pf Pac. Dim. No 319 http://homepage3.nifty.com/ebina2540...D0601-0700.htm Couldn't cross it easily, big voltage and amperage. |
| These show qty 41 in Canada. http://www.doom.com/search.php?q=2sd646a Al
| Using surplus servo motors as spindle drive | Swede | Servo Motors and Drives | 11 | 03-16-2008 09:05 AM |
| Driving a 4 pole ac servo with a 6 pole drive | TommyB | Servo Motors and Drives | 4 | 04-28-2005 02:17 PM |
| Where can I find Detail Specs Servo & Drive MEans ? | Calico | Servo Motors and Drives | 1 | 02-28-2005 12:37 PM |
| Cheap 0 Clifton and servo drive selection (advice needed) | Konstantin | General Electronics Discussion | 4 | 04-14-2004 11:21 AM |
| R90H Servo Drive | Verboten | Servo Drives | 16 | 03-30-2004 10:10 PM |
