Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Rutex Products > Servo Drives
Servo Drives Discuss all Rutex servo drives and get direct support!
Old 06-20-2004, 09:33 AM
FrankdB is on a distinguished road
problems with tuning of Rutex drives
I have some problems with my R990H drives:
First I worked with one drive only and made the custom cable as described in the manual. This setup works well, I am able to see all the values of the drive and to tune it. However, when I use the motherboard and the special made SPI connector, all the values are rapidly changing or the program sees no drives or it says that I have an old revision number of the firmware. In other words something is wrong with the communication between th pc and the drives.
Can someone point me to the right direction?
Frank
Old 06-20-2004, 06:05 PM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
When using the mother board. do you use the resitors across pin 1-2 and 3-4 ?
Read about it in the manual. You need these just when you are tuning your drives.
Old 06-21-2004, 04:16 AM
Hi Ynneb,
According to the manual I have pin 1 and 2 and pin 3 and 4 connected to get the drives in SPI mode. I think I had a bad connection( although I used the same cable with my geckos) between the motherboard and the printerport. The next day I re-connected everything and the whole system was working.
Thanks anyway,
Frank
PS: Now and then I have some quirks in my Y and Z motors. Today I gonna make some new encoder connections
2000 series Rutex drives rutexus Servo Drives 19 04-03-2007 05:00 PM
Inductors with Rutex Drives MMT Servo Drives 4 03-13-2005 05:59 PM
Help to setup Rutex drives Moondog Servo Drives 3 07-12-2004 05:26 AM
Rutex Drives mikburts Servo Drives 0 05-01-2004 08:55 AM
Rutex Drives mikburts Servo Drives 4 04-10-2004 08:16 AM
