Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Rutex Products > Servo Drives
Servo Drives Discuss all Rutex servo drives and get direct support!
Old 05-11-2004, 08:09 AM
mikburts is on a distinguished road
Question PMI shaftless encoders
Benny suggested that I ask the forum for help. Need help to identify wiring on PMI encoders. Color of wires and pictures are attached.
Wire color code is
red
black
green
orange
white (black tracer)
white(blue tracer)
white
bare wire from shield
mikburts
Old 05-11-2004, 08:11 AM
Pictures didn't go through so I will try again.
Mike
Old 05-11-2004, 08:28 AM
These picture are a learning experience.
Thanks for having patience
Mike
Old 05-11-2004, 09:17 AM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
I suggested the red and black wires would probably be the power supply wires. ( Voltage unknown though, I suspect 5 volts )
I figured if you had the power supply wire connected ok, it would be a matter of trial and error for the signal wires.
But a second and third opinion would be even better than an educated guess.
Old 05-11-2004, 10:16 AM
Splint is on a distinguished road
Perhaps try asking the manufacturer of the encoder, if it's not too old they may have all the info you need, also have a look if there is any identifying lettering where the wiring is soldered to the board.
Old 05-11-2004, 05:34 PM
I found PMI Encoder info
Ynneb Splint
I found a servo repair facility that had the wiring config.The servo mfg (PMI) only puts their name on them. The tech rep. had a book with the info.
Mike
Red- +5 Volts
Black- Comm
Green-- Index
Orange- Index Not
White (brown tracer)- A Not
White(blue tracer)- B Not
White- Channel A
Blue- Channel B
Bare-- Ground
Old 05-11-2004, 05:43 PM
Al_The_Man's Avatar
Aha you threw us a curve ball, you missed a wire the first time!
If PMI just put their name on them I would guess they are Renco, they look the same.
Al
Old 05-11-2004, 05:50 PM
IT must be the bifocals
Al
thanks for the reply. At 62 the eyes play tricks on you.
Mike
Old 05-11-2004, 06:08 PM
Al_The_Man's Avatar
Mike, I don't know if you have used this encoder type before, but if not a couple of tips on mounting, with the Renco type, after the encoder is slid on the shaft the board c/w reading head is secured first and then the aluminum bushing with the rotary scale is pushed down as far as it can go before securing the allen set screw, you should hold the motor/encoder up so that you can check to see if there is gap both sides of the glass disk and reading head. Make sure there is no endplay on the motor shaft before mounting, if there is it is possible for the disk to move against the head and destroy it.
Also, always mount pulleys, drive gears etc to the outgoing shaft first, as any tapping or driving on of this kind is not good with the encoder in place.
Al
Old 05-12-2004, 08:07 AM
Encoder Info
Al
Many thanks for tips on installation. This time and one more will be two. Good sources of information and sharing it makes this forum strong. Again thanks Al,Benny and Splint for response to my need for info.
Mike
  #11   Ban this user!
Old 05-12-2004, 09:30 AM
rutexus is on a distinguished road
Mike,
Some encoders draw a lot of current all the time. I encourage people to stick to the US Digital encoders if possible because they use the Agilent (used to be HP) sensors, they draw little current, they have many mounting options, they are reasonably priced, easy to mount, have excellent documentation and support. I am not familiar with the encoders you are asking about. Hopefully you can find support from some of the men who have used them.
Tom Eldredge
Old 05-12-2004, 09:38 AM
ynneb's Avatar
Moderator
If they are Renco as Al suspects, I have heard of an issue about them drawing too much current and not working with Rutex drivers without a seperate power supply to them. ( I suspect that might be why Rutexus has responded here.) Well I have used 3 of the Renco encoders with the Rutex drives and they are working fine. I did not need a seperate power supply for them.
If however you do get stuck, it is a simple process of connecting a 5 volt power pack to them.
Which encoders? heathmanc Servo Motors and Drives 4 06-09-2005 11:02 PM
What encoders to use for these motors? Cold Fusion Servo Motors and Drives 9 06-03-2005 12:14 AM
Renco open end encoders ynneb General Electronics Discussion 3 03-23-2004 10:52 AM
Stepper motors, encoders... runnoahrun General Electronics Discussion 6 02-28-2004 10:59 PM
encoders with steppers turmite General Electronics Discussion 2 01-31-2004 09:44 PM
