Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Rutex Products > Servo Drives
Servo Drives Discuss all Rutex servo drives and get direct support!
  #13
Old 05-12-2004, 12:32 PM
Al_The_Man's Avatar
Benny, I personally have not had a problem with any manufacturers encoders drawing too much current, especially if they are of the differential TTL line-driver type, most I find draw about 100ma (150ma tops), which I would say should be peanuts for any system. You Might run in to a problem if you use single ended open-collector type and use a small value pull-up resistor or the like.
Al
  #14   Ban this user!
Old 05-14-2004, 07:16 AM
mikburts is on a distinguished road
Encoder mfg. identified
Al,Benny,Tom
The encoders are a product of Kollmorgen.
Specs.
500 lines per rev
+5 volt
A channel
A not
B channel
B not
Index channel
Index not
Max draw 200 Ma
This info came from a Kollmorgen product manual.
In South Carolina, USA
Mike
Which encoders? heathmanc Servo Motors and Drives 4 06-09-2005 10:02 PM
What encoders to use for these motors? Cold Fusion Servo Motors and Drives 9 06-02-2005 11:14 PM
Renco open end encoders ynneb General Electronics Discussion 3 03-23-2004 09:52 AM
Stepper motors, encoders... runnoahrun General Electronics Discussion 6 02-28-2004 09:59 PM
encoders with steppers turmite General Electronics Discussion 2 01-31-2004 08:44 PM
